Lambda sensors
This is a discussion on Lambda sensors within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi, Using Vag Com 409, i get the following Lambda sensor readings; at idle; group 006 = -7 and 18, ...
Old 18-02-2008, 13:41   #1
Default Lambda sensors
Hi,
at idle;
group 006 = -7 and 18, group 008 = 5.5 and 2.3.
When i throttle (accelerate in neutral) to 2500rpm quickly, the lambda readings change to;
group 006 = 5.5 and -0.8, group 008 = 1.6 and 2.3 (the 2.3 reading does not change at all!)
Can anyone explain why there are 4 lambda readings and what these reading should be if the car is functionally normally?
Car is a 99 golf mk4 1.8T
Thx
pang is offline
Old 19-02-2008, 18:11   #2
Theresias's Avatar
Default Re: Lambda sensors
What's your ECU part number?
Sebastian
Theresias is offline
Old 20-02-2008, 16:02   #3
Am not sure. Vag com provides me the following numbers;
Controller: 06A 906 018 R
Component: 1.8L R4/5VT MOTR HS D06
Is this what you was after?
pang is offline
Old 20-02-2008, 16:08   #4
Theresias's Avatar
Yeah, that's what I was looking for. Here's an excerpt from the AGU label file.
6,0,Idle Stabilisation - Spec figures at Idle
6,1,Idle speed,800-920 rpm
6,2,Idle reg,-10-10%
6,3,Lambda reg,-10-10%
6,4,Ign angle,6-12 BTDC
7,0,Lambda learned values
7,1,Lambda reg,-10-10%
7,2,Probe volts,0-1V
7,3,Valve duty,angle 0-99%
7,4,Correction,0.3-1.25
8,0,Lambda learned values
8,1,Inj. period,1-3 m/s
8,2,Idle learned,-10-10%
8,3,Learned,-8-8%
8,4,Vent mode
Sebastian
The Following User Says Thank You to Theresias For This Useful Post:
pang (21-02-2008)
Old 21-02-2008, 10:10   #5
Thanks Sebastian.
Does this mean that the Lambda sensor is faulty? In group 8, the learned lambda readings do not change...stays at 2.3.
The symptoms i am seeing from the car is that the turbo is non existent! (8 - 50mph took 8secs in 2nd gear - maf read 116g/s at 6000rom).
Also fuel economy is really poor, 20mpg!
pang is offline
