This is a discussion on Measuring compression? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Am i right in thinking that vagcom somehow measures the pressure in the cylinders or compression? There is a reading ...
| Briskodian Join Date: Feb 2005 Location: Mid Beds
| Am i right in thinking that vagcom somehow measures the pressure in the cylinders or compression? There is a reading for each cylinder but wonder what it represents. How tight are the recommended ranges for the measured values you can see? I know you can measure a lot of things but i'm not sure whether they are good or bad without know exactly what they should be reading.
__________________ Fabia vRS forunner to the Bentley Continental GT Briskoda - Skoda's illegitimate family Mods: Superchip, K&N filter, Eibach springs, FSD dampers, black front grille, |
