This is a discussion on No response from controller within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Righto just got VAG-COM and cant get it to work with the octy Done the test as it passes but ...
| Briskodian Join Date: Apr 2006 Location: Baarnsley
Members Car: MK1 Red Octy vRS Thanks: 39
| No response from controller Righto just got VAG-COM and cant get it to work with the octy ![]() Done the test as it passes but get CAN: Not Ready When ever i try to access something i then get what it says below in the attachment Anyone have any ideas? I wouldnt mind but i managed to scan through my brother Ibiza last night with it fine |
| Briskodian Join Date: Jul 2007 Location: Oxfordshire
Members Car: Octavia Vrs Thanks: 43
| Re: No responce from controller try disconnecting your battery for a while then attempt again.
__________________ Must Go Faster |
| Re: No responce from controller thanks for that will give that a go later on |
| Briskodian Join Date: Feb 2006 Location: North East Hants
Members Car: K04 equipped ;) Images: 2 Thanks: 48
| Re: No responce from controller Which flavour of Octavia are you using it on? |
Members Car: '97R BMW 328i Saloon Thanks: 728
| Re: No responce from controller Being CAN I'd guess a Mk2. ![]()
| Briskodian Join Date: Jul 2006 Location: Cleveland + Windsor
Members Car: Passat Sport TDi Images: 1 Thanks: 211
| Re: No responce from controller It could be a MK1... the test result will show 'CAN: NOT READY!'... which is fine on a mk1. |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: No responce from controller Let's start all over here... #1 Which interface hardware are you using (i.e. what does the label on it say)? #2 What do the 7th and 8th digit of the VIN say?
__________________ Sebastian |
| Re: No response from controller Sorry its a MK1 so 1U chassis The interface is HEX-USB + CAN |
| Re: No response from controller Then the CAN not ready is normal since the 1U doesn't have a diagnostic CAN. So the real question is why can't you communicate with the cluster? I assume you are able to talk to other modules just fine?
| | #10 |
| Re: No response from controller No thats what i dont get. I tried to do the auto scan and it fails. Try's 3 times on each and then moves on to the next but every time i go into test the interface it will pass |
| | #12 |
| Re: No response from controller I get as below Port Status: OK Interface: Found! Type: Ross- Tech HEX-USB+CAN Version:1.78 Status: Ready K1: OK K2: OK CAN: Not Ready |
| | #13 |
| Briskodian | Re: No response from controller That's fine. Since it worked in your brother's Ibiza, the logical deduction is that there's something awry with your Octy. First, check that the cable is fully seating in the socket. -Uwe- |
| | #14 |
| Re: No response from controller Well thats what i though as like you said it worked fine in an Ibiza (6K) Ill check the socket as its in a stupid place and not the easiest to to secure properly |
| | #15 |
| Re: No response from controller Well i tried it again today and it works fine so god know what was happening with it |
| | #16 |
| Briskodian | Re: No response from controller hi. i don't know but it seems to be a problem with vagcom licence. your cable is an 704 like mine... in the beginning my cable shows this and after that, the cable died... (sorry for my language...!) bye
__________________ Octavia 2 RS TDi. 1000km and DPF one time cleaned... |
| | #17 |
Members Car: Audi S3 Thanks: 195
| Re: No response from controller If your cable was a copy and not a genuine cable then it may well have had a firmware update which killed it.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| | #18 |
| Re: No response from controller Mine is working now anyway |
| | #19 |
| Briskodian Join Date: Apr 2008 Location: MARCH
Members Car: SKODA OCTAVIA 2.0 WITH 18" RS4 ALLOYS Thanks: 2
| Re: No response from controller I HAVE THE SAME PROBLEM TOO MAYBEE I DID NOT CONNECT IT PROPERLY ![]() LAPTOP RECOGNISES LEAD AND THE LED LIGHTS WHEN I CONNECT TO THE CAR BUT IT SAYS ABOUNT THE CONTROLLER. WHAT IS THE CONTROLLER?? IS IT THE ECU??? |
| | #20 |
| Re: No response from controller Please turn off your caps lock, it is considered shouting on an Internet Forum. Thanks.
| | #21 | |
| Briskodian | Re: No response from controller Quote:
For more assistance, we need much more information. What type of interface are you using? Are you sure the drivers for that interface were properly installed? Did you go to [Options] [Test] and verify that the interface was working? | |
| | #22 |
| Re: No response from controller yes everything tested ok on the test but when scanning various addresses for modules i get the no response from controller apearing. i have tried changing the com ports etc on device manager but still no good. |
| | #24 |
| Briskodian | Re: No response from controller Hello I have the same problem getting no response from controller every time i try. My cable is not ross-tech original. It just says OBD-II on the adaptor. The led works ok when I connect it to the car and the interface test looks ok. I'm using VAG COM 409.1 release. Any ideas? |
| Thanks for the quick response | delcac | Impossible Performance | 13 | 06-07-2007 22:40 |
| No Response from Controller | ckinsella | Diagnostics & VAG-COM | 12 | 17-10-2005 18:46 |
| Galloways response to the US Norks | camerashy | Off Topic and Chit Chat | 2 | 19-05-2005 21:19 |
| Gauging the response for 2 new how to's | HellFire | Fabia I | 12 | 11-05-2005 13:58 |
| Throttle Response | kartingmofos | Octavia I | 3 | 10-03-2005 19:15 |
