Octavia I seatbelt warning chime
This is a discussion on Octavia I seatbelt warning chime within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Sorry for yet another new thread! I want to turn off the irritating chiming noise my 2002 Octavia I makes ...
Old 04-03-2008, 13:53   #1
AJB
Default Octavia I seatbelt warning chime
I want to turn off the irritating chiming noise my 2002 Octavia I makes after I turn on the ignition until I do up my seatbelt.
I've bought myself VAG COM, and was hoping that clearing "Seatbelt Warning active" in the Instrument Cluster coding would do the trick.
Unfortunately that just seemed to turn off the dash warning light for seatbelts (which comes on for a while after the ignition's turned on, regardless of whether you've done the belt up), but didn't seem to affect the chime.
Does anyone know a way to turn off the chime, or do I just have to live with it?
Thanks very much,
Alan
AJB is offline
Old 04-03-2008, 14:51   #2
Theresias's Avatar
Default Re: Octavia I seatbelt warning chime
Appears that some Octavia (1U) clusters just ignore the coding, so yes you may have to live with it.
Sebastian
Theresias is offline
Old 04-03-2008, 15:18   #3
Gizmo68's Avatar
I tried this on a MKI also and it ignored it too.
The only way then is to unplug the wire that goes to the female part of the buckle.
Easy job to do:
raise the seat as high as possible
look for the 2 wire plug going to the buckle (by the tunnel)
unplug & cable tie plug out of the way
Job done!
Before anyone says it will throw up faults / effect airbags etc, no it doesn't. It is is a simple loop that when the seatbelt is connected it breaks the connection so turns the light and warning chime off,
just the same as disconnecting the plug also breaks the loop, so the light and chime is fooled into thinking the belt is plugged in.
Gizmo68 is offline
The Following User Says Thank You to Gizmo68 For This Useful Post:
RobClubley (06-03-2008)
Old 04-03-2008, 15:30   #4
AJB
Fantastic - thanks for that. Will try it this evening!
AJB is offline
Old 05-03-2008, 12:42   #5
AJB
Unplugging the switch under the seat worked perfectly.
Thank you!
AJB is offline
Old 05-03-2008, 15:47   #6
Gizmo68's Avatar
Gizmo68 is offline
Old 06-03-2008, 00:32   #7
Ta moko!
RobClubley's Avatar
Useful to know, thanks.
Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand!
Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge
www.pimpmyskoda.co.uk www.clubley.org Facebook
RobClubley is offline
Old 06-03-2008, 00:59   #8
Get out the way
Taxi 219's Avatar
Mine will only chime 3 times then stops and i never use my seatbelt as us Taxi drivers are exempt from using them.
Car now: 56 Octavia MK2 1.9TDi Ambiente
Previous: 06 Octavia Mk1 1.9TDi Classic with + pack
Sadly missed: 97 Nissan Primera 2.0TDi SLX
Taxi 219 is offline
Old 06-03-2008, 13:03   #9
AJB
Mine does maybe 6 or 8 chimes then stops. Or at least it did. Now it does none at all, which is so much better!
AJB is offline
Old 06-03-2008, 13:18   #10
Fezboy's Avatar
Why would you do that
Octavia VRS
A standard looking car with a twist of Impossible Performance
Support Briskoda join Freedom ======>
Fezboy is offline
Old 06-03-2008, 13:41   #11
kenny rsell's Avatar
Why not put seatbelt on before turning on ignition??= no warning chime.
Diamond silver octavia vRS,xenons,Jetex downpipe with sports cat,Jetex cat back system,Green panel filter,Forge i pro remap,Forge 007 dv,Milotec bumper grills,TT arch vent mod.
kenny rsell is offline
Old 06-03-2008, 13:43   #12
Briskoda Staff
VRStu's Avatar
I've never heard of Taxi Drivers being exempt from wearing them. If you are meaning the regulations covering delivery drivers then these were changed in 05. You can only be excused if there is 50m or less between stops.
Stu - Freedom Pimp
Stu's Car - 2007 Octavia vRS, Race Blue, Xenons, Columbus Navigation, Rear Parking Sensors, Maxi Dot, Light Assist, Jumbo Box, 18" Alloys, Stu's Cruise Control & OEM Integrated Bluetooth Telephone.
Something for Weekend - 2002 Lotus Elise RaceTech, Gunmetal, Radio, Carpet Mats.
VRStu is online now
Old 06-03-2008, 13:44   #13
Loz
Bad Loz!!
Loz's Avatar
Location: here..................... sometimes there........
I can't not wear my seatbelt, it feels too weird lol. I actually like feeling it on me
Lorraine- AKA Loz, Lozkins, Lozza, Lozzy, Lozlet, Lozzette, Lozzle, Lozraine, Lozalot, Lozatron, Lozatronic, Lozatroonathoone, Lozlatina, Loztalot, Lozingtonrain, Lozinator, Lozenge, Lozenger, Lozmanaught, Lozzy Loo, Lozzybear, Lozzy-wozzy-dooh-dah-day, () CouLoz of the rainbow, Lozano, Lozvaldo, Lorraineo, Lorrainickle, Lorrainus, Lez, Lezkins, Randomer & Mizz LB
Can't change the way I am, sexy, naughty, bitchy!
Loz is offline
Old 06-03-2008, 16:28   #14
I know where i live private hire dont wear seatbelts when carrying passengers as the seatbelt could be used to restrain or strangle the driver!
But think its more of a toleration by the police and not an actual exemption
Mind you the way "some" of the taxis drive i would hope they are wearing seatbelts for their sake!!
tartanarmy is offline
Old 06-03-2008, 18:01   #15
AJB
Partly because the key is already in my hand from unlocking the door, so the ignition is the obvious place to put it, but mainly because it gives the engine a couple of extra seconds idling (whilst I do the seatbelt up) to get some oil around before I drive off.
AJB is offline
Old 06-03-2008, 23:37   #16
VRSPhil's Avatar
Taxi drivers are exempt from wearing a seat belt because of the risk of it being used as a restraint or means of attack (against them).
Octavia vRS WRC
VRSPhil is offline
Old 07-03-2008, 04:41   #17
Get out the way
Taxi 219's Avatar
Yes that is exactly correct.We are and it is in the law that in our own districts that we are licensed under we are exempt from wearing seatbelts because of attacks on taxi drivers.If we travel out of our district then we must wear them by law.Dorset Police have never stopped any of us because of not wearing a seatbelt as they know this law too.
Taxi 219 is offline
Old 07-03-2008, 08:37   #18
Fezboy's Avatar
Probably the same them as to why you can all use your HAND HELD radio 1,000,000 times a day
Bluethooth should be made law
Octavia VRS
Fezboy is offline
