40,620 Members 1,518,625 Posts
One for Cheffie
This is a discussion on One for Cheffie within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Ran Vag-Com on cheffies octy this morning - can anyone advise on the source of(and solutions for) the following codes; ...
Old 11-12-2006, 21:55   #1
bigad's Avatar
Members Car:
Question One for Cheffie
*NOTE* The radio works fine, but has faults - even after being cleared. I think it may have something to do with his cigar lighter mod perhaps causing interference or something.
For the two engine faults I don't know - someone will be along shortly........
Cheffie, has the light come back on yet??
VAG-COM Version: Release 409.1-US
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01: Engine
Controller: 06A 906 032 HN
Component: 1.8L R4/5VT G 0002
Coding: 11500
Shop #: WSC 31480
2 Faults Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480
No fault code found.
Address 08: Auto HVAC
Controller: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31480
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1U0 920 911 C
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 19412
Shop #: WSC 25031
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
1 Fault Found:
01304 - Radio
Address 46: Central Conv.
Controller: 1C0 959 799 B
Component: 3Y Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 31480
Address 56: Radio
Controller: 1U0 035 161 D
Component: Radio GRO 0001
Coding: 00403
Shop #: WSC 26024
End --------------------------------------------------------------------------------------------------
bigad is offline
Old 11-12-2006, 22:01   #2
Partner
Lummox's Avatar
Images: 2
Re: One for Cheffie
Do a search for 17705, its well covered on here.
www.unit18.co.uk
Lummox is offline
Old 11-12-2006, 22:52   #3
cheffie's Avatar
Members Car:
Re: One for Cheffie
Hi guys, No the light has not come on yet!!!!!!!!
cheffie is offline
Old 11-12-2006, 22:56   #4
cheffie's Avatar
Members Car:
Re: One for Cheffie
Just read a couple of 17705 threads, I have got a K&n panel filter in??
cheffie is offline
Old 11-12-2006, 23:01   #5
Partner
Lummox's Avatar
Images: 2
Re: One for Cheffie
Shouldnt make much of a difference.
Any odd noises at idle, maybe a hissing from the front of the engine?
www.unit18.co.uk
Lummox is offline
Old 11-12-2006, 23:09   #6
cheffie's Avatar
Members Car:
Re: One for Cheffie
Not that i've noticed, and seems to drive ok!
cheffie is offline
Old 11-12-2006, 23:10   #7
Partner
Lummox's Avatar
Images: 2
Re: One for Cheffie
Then its some good old diagnosis needed then,
www.unit18.co.uk
Lummox is offline
Old 11-12-2006, 23:15   #8
cheffie's Avatar
Members Car:
Re: One for Cheffie
Do you mean take it into the local stealer???
cheffie is offline
Old 11-12-2006, 23:17   #9
Partner
Lummox's Avatar
Images: 2
Re: One for Cheffie
Or specialist, unless you have diagnosis skills that is.
www.unit18.co.uk
Lummox is offline
Old 12-12-2006, 05:55   #10
Uwe@Ross-Tech's Avatar
Members Car:
Re: One for Cheffie
2 Faults Found:
My money is on an intake leak.
-Uwe-
Uwe@Ross-Tech is offline
Old 12-12-2006, 08:36   #11
Partner
Lummox's Avatar
Images: 2
Re: One for Cheffie
Agreed, usually the vacuum pipes under the inlet manifold. Or another boost leak of some description, also known cause is the throttle body.
www.unit18.co.uk
Lummox is offline
Old 12-12-2006, 23:22   #12
cheffie's Avatar
Members Car:
Re: One for Cheffie
Thanks guys for your replys.... Phoned the local stealer today, told tim that i had vag commed the car and told him about 17705 error code. He had NEVER heard of it.
cheffie is offline
