40,620 Members 1,518,629 Posts
Please HELP before I throw USB vag-com cable in the bin!
This is a discussion on Please HELP before I throw USB vag-com cable in the bin! within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; I've got a USB vag-com cable which I bought from ebay. It was £30 and seemed better than the £5 ...
Old 19-11-2006, 13:35   #1
VRSPhil's Avatar
Members Car: Passat Sport TDi
Images: 1
I've got a USB vag-com cable which I bought from ebay. It was £30 and seemed better than the £5 hong-kong versions! When I plug it in, the computer recognises it as a USB <> serial interface and installs its own drivers I got a driver on a disk with the cable as a .rar file and also downloaded a similar looking driver from an auto diagnostics site. When I find the cable in the device manager and click "update driver" it asks where to look for the driver so I point it at the .rar file and it just says it can't find any better drivers than the ones it has installed already. I have tried unzipping the .rar into another folder and that didn't work either.
Sorry if this seems retarded to people in the know, I'm not really a computery person
VRSPhil is offline
Old 19-11-2006, 13:43   #2
mello in yello
postmanpat's Avatar
Members Car: fabia vRS/ octavia vRS
Re: Please HELP before I throw USB vag-com cable in the bin!
D'ont understand the problem if a driver is allready installed that is the equivalent to the one in the.rar file
Originally Posted by Emily-Elizabeth
Sperm donership: It is not like giving blood, it is tossing away...............
Postmanpats car Fabia vRS Zennons, ESP, autochanger, 3rd headrest, heated seats, cruise control
SWMBO Octy Mk2 vS maxidot, duel zone wotsit, cruise, parking sensors, 18" alloys
postmanpat is offline
Old 19-11-2006, 13:46   #3
VRSPhil's Avatar
Images: 1
It's not an equivelant, windows just seems to think it is. It's installing it as a usb to serial converter, not a vag-com interface. When I go into vag-com it can't find an interface...
VRSPhil is offline
Old 19-11-2006, 13:51   #4
mello in yello
postmanpat's Avatar
not brilliant with computers and somebody else will probably come along and contradict me but, can't you uninstall what you have allready then custom install from the disc when windows finds the device again from scratch?
Old 19-11-2006, 13:55   #5
VRSPhil's Avatar
Images: 1
I've tried that, as soon as I plug it in it finds it and installs it automatically without asking me anything Thanks for your input.
VRSPhil is offline
Old 19-11-2006, 14:57   #6
Hardcore
Basil's Avatar
Members Car: Fabia vRS
you have to use a program called windows archiver or the like that upzips the .rar file (.rar = more efficient .zip file). Just do a search for .rar freeware.
several files will unpack and all will be fine after that!!
HTH
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 19-11-2006, 15:22   #7
C+ à Paris!
tfboy's Avatar
Members Car: "Fake" Black Magic vRS
What Bas said WinRAR archiver, a powerful tool to process RAR and ZIP files get winrar. that will allow you to extract that .rar file and you should have a .inf file and other bits Windows will be able to use
Xavier
tfboy is offline
Old 19-11-2006, 16:11   #8
Uwe@Ross-Tech's Avatar
Members Car:
That's generally correct for a third-party interface. Third-party USB interfaces almost always emulate a serial port. VAG-COM cannot access them directly.
Look in Device Manager and see which COM port is being emulated. If it's higher than COM4, you'll need to tweak it into the COM1 to COM4 range. Then select the corresponding port in VAG-COM.
See also:
Ross-Tech: VAG-COM: FAQ Page 3
-Uwe-
Uwe@Ross-Tech is offline
Old 19-11-2006, 16:33   #9
VRSPhil's Avatar
Images: 1
Thanks to all. I have tried unzipping the file with winrar but when trying to update the driver for the interface, I point the device manager at the folder containing the unzipped files and it just says it cant find any drivers. It says the same when used with the .rar which came with the cable and with the .rar I downloaded.
If I plug the cable into the computer and get the "found new hardware" thing in the corner it just installs itself as a USB to serial converter. When I looked at that in the device manager it was set as com port 6. I changed it to com port 4 and then in vag com I tested com port 4 but it just said "Port status : OK, Interface : NOT FOUND" but I'm guessing that is because I have been unable to install the correct drivers
VRSPhil is offline
Old 19-11-2006, 16:36   #10
C+ à Paris!
tfboy's Avatar
Phil, what files are in the rar file?
Xavier
tfboy is offline
Old 19-11-2006, 16:43   #11
Hardcore
Basil's Avatar
Keep fiddling mate, you'll get it sorted eventually...
otherwise find a pimply teenager to sort it out
Good luck!
Basil is offline
Old 19-11-2006, 16:49   #12
VRSPhil's Avatar
Images: 1
This is a screen shot of the files I get from the .rar
Don't know about asking a pimply teenager for help.... I might strangle one with the cable though!
VRSPhil is offline
Old 19-11-2006, 17:16   #13
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
The RossTech guy's have a good guide which may help with installing USB drivers -
Ross-Tech: VAG-COM: USB Driver Installation
Stu
VRStu is offline
Old 19-11-2006, 17:42   #14
Members Car:
I suggest you run the uninstall program (the one with the picture of a chip)
That should get rid of the existing drivers.
Download the latest drivers from here:
Virtual COM Port Drivers
Then start again reinstaling the USB cable & drivers and sorting out the comms port numbers, I don't think VAG-COM will see the interface until it's powered from the car.
Are you using any other USB device that uses the FTDI chip & drivers? If you are you may have some conflicts.
My advice is to buy the proper VAG-COM cable that can use the direct FTDI drivers these are much better at handling the precise timing required for this sort of application.
Chris_55 is offline
Old 19-11-2006, 20:09   #15
Fabian
bryand's Avatar
Members Car: Volvo C30 2.0D
Was the lead connected to the car, with the ignition on? The "Interface not found" could be because it isn't doing anything or because it relies on the car's diagnostics socket for its power, not the USB port in the computer.
bryand is offline
Old 19-11-2006, 23:01   #16
I parked up 1st
ric04vrs's Avatar
Members Car: silver Fabia VRS
i set mine to COM port 2 or 3 iirc , i think what you've also got to watch is that even though you are using it through the USB connector , you have got to set VAG COM saying you're using the serial connector , thats what i had to do on mine anyway
very bored and liable to do something stupid
ric04vrs is offline
