This is a discussion on Radio & Navigation fault code in CAN Gateway within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi, I've done a few searches for this but not found an answer yet, so here goes!! I've removed the ...
| Briskodian Join Date: May 2006 Location: S Yorks
| Hi, I've done a few searches for this but not found an answer yet, so here goes!! I've removed the MFD 2 from my octy 2 vRS & replaced it with a Columbus . Very pleased!vrStu helped me code it in, and it seems to work ok. I get the fault code come up for the missing second aerial, which I know about, however in the Can Gateway I keep getting the following: 2 Faults Found: 1300 - Control Module for Navigation with CD-Rom (J401) 004 - No signal/Communication - intermittent Freeze Frame: Fault Status:00100100 Fault Priority: 2 Fault Frequency: 7 Reset Counter 134 Mileage 56373 km Time Indication: 0 Date: 2000.00.00 Time 15:06:50 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status:00100100 Fault Priority: 2 Fault Frequency: 7 Reset Counter: 134 Mileage: 56373 Time Indication: 0 Date: 2000:00:00 Time: 15:06:50 I'm guessing here that it is recognising that the old MFD2 is no longer there, but how do I stop it from continuing to report this as a fault? Is there a way of telling the CAN gateway that the Controler is no loner there or deleting it? Cheers! |
| Briskoda Staff Join Date: Dec 2004 Location: Hampshire
| Bruce Check your connections for the phone, make sure that is not causing a break in the CAN communications. You'll need to take the radio out to check this but it's possible that a wire has been trapped/pulled when you did the swap over. You get it twice because the Radio & Nav on the Columbus are the same controller. Shouldn't be connected to the removal of the MFD2.
__________________ Stu - Freedom Pimp Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - Hmm, Have a guess...... ![]() SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Cheers Stu, that makes sense. I'll check it out. Would this affect how things work as I can't say Ive noticed any problems? |
| Alarmist Join Date: Feb 2006 Location: North East Hants
| I get the same Bruce and I also did the swap from MFD2 to Columbus. Hopefully a very nice man will take a look in the very near future. ![]()
__________________ ![]() Pentax K10D, Tamron 18-250mm lens and a lot of luck. |
| Thanks guys, just checked the back of the set, couldn't see anything which was trapped or loose, but It seemed to go in much easier this time! Will have a "pootle round" in a bit & check it again! Let me know if you find out what caused it on yours |
| The only other thing that I can think of is the Gateway support for the Columbus, obviously the Columbus is quite new and I know Ross-Tech had to make some changes to VAG-COM/VCDS to allow communication with the Columbus.
| Briskodian Join Date: Apr 2007 Location: catterick garrison
| does this mean a mfd2 is up for grabs
__________________ ps3 id is bob5500 IF IN DOUBT FLAT OUT..... |
| I think you missed the boat on both counts there.
| Hmmm. Yeah, that could also be true. I'm booked in for a 40K service on Saturday, so I will ask the master tech if it needs updating. Will plug in Vag com later when I've done a few miles & see if it crops up again. |
| | #10 |
| oh well
| | #11 |
| What year is your car Bruce?
| | #12 |
| | #13 |
| | #14 |
| Hmm - Could tie in with the gateway theory then. There is lots of talk about early VW's needing CAN adaptors just to get the units working.
| | #15 |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
| All PQ35 (i.e. Golf 5 and Octavia 2) based models use the same sort of CAN databus. The difference you are supposedly referring to is TP1.6 (like it is being used in the PQ34 (i.e. Golf 4 and Octavia 1) versus TP2.0 in the PQ35 (TP stands for Transport Protocol). There is no need for any sort of adapter in this case. However, to finally answer the original question we've seen these codes a couple of times now and as far as we can tell this is a common issue with the RNS510/Columbus. Under certain circumstances the unit seems to timeout on requests/messages from the Gateway which then creates this fault code. It is possible that newer gateway software versions have a higher threshold regarding this timeout but at the end you can just ignore those communication codes unless you actually have functional issues which you can track down...
__________________ Sebastian |
| The Following 2 Users Say Thank You to Theresias For This Useful Post: | uncle bulgaria (20-05-2008),
VRStu (20-05-2008)
| | #16 |
| Thanks for clearing that up Sebastian
| | #17 |
| Just spoke to our dealer, latest software updates came in last week, so have asked to have it checked out as the last update it had was 2 years ago when it had the standard Stream HU! Only downside, have had to put it off until 31st as they are now overbooked. As i've now got the car on Saturday, I might get the modding done that i've been planning |
| | #19 |
| Not sure, it sounded like a "service pack" kind of thing as he said it contained the "latest updates and all previous ones in one". Anyway it hasn't been plugged into VAS for a long while, so it will be interesting to see what happens! |
| | #20 |
| Might be worth saving a full autoscan so that you can see what has been updated.
