Results from VAG COM scan Help Please!!!
This is a discussion on Results from VAG COM scan Help Please!!! within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi Just had a chap scan the car and got the following faults:- ddress 08: Auto HVAC Labels: 6Q0-820-045.lbl Part ...
Old 01-07-2008, 19:12   #1
Default Results from VAG COM scan Help Please!!!UPDATE
Hi
Part No: 6Y0 820 045
Component: Klimaanlage X0840
2 Faults Found:
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
31-10 - Open or Short to Ground - Intermittent
And this one:-
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 25032
2 Faults Found:
00566 - Steering Assistance Operation
27-10 - Implausible Signal - Intermittent
01288 - Terminal 30; Steering Assist
07-10 - Signal too Low - Intermittent
And this one:-
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25754
Shop #: WSC 13765
1 Fault Found:
01598 - Drive Battery Voltage
Any help ideas in plain english would be a great help.
Thanks
Mike
mikebh50 is offline
Old 01-07-2008, 19:21   #2
U18 Automotive
Lummox's Avatar
Default Re: Results from VAG COM scan Help Please!!!
2nd and 3rd are linked. Both could be realted to a flat battery or low battery voltage for whatever reason.
Top one is due to the a/c system being low on gas or a faulty switch.
Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
Old 01-07-2008, 19:28   #3
Hi
Thanks for the quick reply seems a bit strange as i fitted a new battery about 2 months ago could this point to the alternator?Also the air con was re gased when i bought the car about a year ago and worked fine then so i may have a leak some where?.
mike
mikebh50 is offline
Old 01-07-2008, 19:30   #4
U18 Automotive
Lummox's Avatar
Were the fault codes cleared after the battery was changed?
Is the a/c working now?
Lummox is offline
Old 01-07-2008, 19:52   #5
Mouse's Avatar
What the great Lummox said. Mine has had fault codes after a remap 12 months ago. 2 services later by main dealers, not scanned and not cleared.
If every dealer had Lummox, Skoda drivers would be chimming.
Black Magic Fabia v/RS
Skoda Fabia VRS ! Practical & Exciting !
Mouse is offline
Old 01-07-2008, 20:56   #6
Hi
No first time anythings been near the car since battery change.But have been get the steering ,abs & sar warning lights intermittently since then but not straight away but not had it for over a week now.Only seemed to happen when engine ticking over and turning wheels then steering goes all heavy.Air con not working at all so need to get that checked but sounds as it might not cost an arm and a leg.All i would say is i had the steering sensor changed under warranty in January could that be anything to do with it?
Mike
Could there be water getting in some where causing these codes as been alright while its been dry?
P.S chap was ok with software but didn't want to change anything.
mikebh50 is offline
Old 15-07-2008, 19:04   #7
Default
Hi
just quick up date booked car in to Robinson's Skoda in Norwich Norfolk for next Thursday.Spoke to chap in the service dept saying that i was getting all the warning lights etc that i had before they changed the steering sensor in January only to be told that they didn't change the sensor but replaced the pump £450.00 worth apparently.Also he informed me that as the pump was changed under warranty and the warranty on the pump only lasted as long as the car warranty which was up on the 19th of March just 2 month later.But if it was the pump that would go back to Skoda and see what they could do.Is this right?.I'm hoping it more of an electrical fault as some people have said about a wire that could need replacing , as it can't be the battery as i have already replaced that.With all this and the bloody air con not working i,m starting to get p--- off with the car.they are charging £74.00 to service the air con which seems a bit steep but hopefully they will fix it if there is a leak.
Mike
mikebh50 is offline
