This is a discussion on Steering Angle Sensor ? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi guys... Just got my car diagnosed with a Vag-Com. It appears to be pointing to the Steering Angle Sensor, ...
| Briskodian Join Date: Sep 2006 Location: Porth (Rhondda, South Wales)
Members Car: Vauxhall Corsa Life (06) 10K Thanks: 7
| Hi guys... Just got my car diagnosed with a Vag-Com. It appears to be pointing to the Steering Angle Sensor, I was just wondering if you guys had any thoughts on the matter. Oah and one other strange thing. The Vag-Com software for whatever reason couldn't connect with my ECU (at least I'm assuming that " 01 " is the ECU.) Again any thoughts would be helpful. Thanks. Address 01 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Address 44 ------------------------------------------------------- Controller: 6Q0 423 156 E Component: Lenkhilfe 0001 Coding: 00110 Shop #: WSC 00000 3 Faults Found: 00566 - Steering Assistance Operation 27-10 - Implausible Signal - Intermittent 01288 - Terminal 30: Steering Assist 07-10 - Signal to Low - Intermittent 00816 - Power Steering Sensor (G250) 29-10 - Short to Ground - Intermittent
__________________ ![]() Fabia ... Gone but not forgotten... |
Members Car: Audi S3 Thanks: 195
| Re: Steering Angle Sensor ? I'd say to reset them and then give it a drive. I'm no expert but from what I see there I'd say the pump may be U/S as well as the sensor. Sometimes codes appear if battery power is a little low.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Re: Steering Angle Sensor ? I had this problem before swapping batteries. I also get the flickering headlights (which everything I've read points to the sensor). Think I'd best swap the sensor first and take it from there. Touch wood it'll not be the pump.
| Re: Steering Angle Sensor ? That's what I would recomend myself, clear the codes and check again later then go for the sensor first.
| Re: Steering Angle Sensor ? Thanks, just ordered it!! £84.88 inc A Pump is over £500 !!!
| Re: Steering Angle Sensor ? Further to the above information. Upon collection of the sensor I had to pay a surcharge of £35.25 !!!! Got it fitted today and the fault is still present ![]() So although Vag-Com claimed my sensor was broken, either there was something else faulty too, or the sensor had nothing wrong with it in the first place. I've just returned from my main dealer where I deposited the old (presumably faulty) sensor and had a refund on the surcharge. ![]() My local garage put the car on VAG-COM and came up with the following error codes. 00566 - Operation Not A Plausable Signal - Intermittent. 01288 - Supply Voltage Terminal 30 to low signal too low - Intermittent. Now I was only given those codes (and text) written on the back of a posted-note, so haven't seen a printout, so have no idea what section the codes belong too. Hopefully someone more knowledgeable will have an idea. The Voltage Terminal sounds like Alternator to me. No idea what the other one is. Any ideas anyone?
| Re: Steering Angle Sensor ? Ideally you'd want to know what controller they were on.
| Re: Steering Angle Sensor ? Well I've googled the codes and they point to fuses & battery. Both of which are good. So not sure what to do next now...
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: Steering Angle Sensor ? Looking like a pump then. |
| | #10 |
| Re: Steering Angle Sensor ? Don't suppose anyone's got a spare pump loafing about doing nothing? ![]()
| Fabia steering angle sensor or Yaw sensor? | Lummox | Technical Guides | 3 | 01-10-2008 23:03 |
| Re: Fabia steering angle sensor or Yaw sensor? | PSbridge | Fabia I | 1 | 27-02-2008 21:18 |
| Steering Angle Sensor | Bian54 | INTRODUCE YOURSELF! First time visitors, say hello here. | 3 | 29-01-2008 23:31 |
| steering angle sensor | markyhedgehog | Fabia I | 0 | 29-12-2006 18:14 |
| Hello Steering Angle Sensor | FirstFurby | Fabia I | 4 | 05-05-2005 19:09 |
