This is a discussion on Timer for heated mirrors.... within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; The heated mirrors on my fabia stay on constant (when the switch is set to on) and i'd like to ...
| Briskodian | Timer for heated mirrors.... The heated mirrors on my fabia stay on constant (when the switch is set to on) and i'd like to set a timer on them for about 10-15 mins, i'm pretty sure this can be done but not sure on where to find 'em in VAG-COM and what settings to change.... Anyone know? Cheers. ![]()
__________________ Black Magic MY07 Fabia v/RS with Cruise, Xennons, Heated Seats, Dension Ice-Link+, Aero wipers & Jabba RARB. |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: Timer for heated mirrors.... You can set the rear window time but not the mirrors. |
| Briskodian | Re: Timer for heated mirrors.... Oh well. How do you adjust the rear window then? IIRC its on for 20 mins standard isn't it?
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: Timer for heated mirrors.... Check/try adaptation channels 03 and 04 of the central electronics control module. I updated our WIKI to cover the details... Skoda Fabia (6Y) Central Electronics - Ross-Tech Wiki
__________________ Sebastian |
| Briskodian | Re: Timer for heated mirrors.... Cheers, will give those a try later.
| Briskodian | Re: Timer for heated mirrors.... Mirrors were set to 254 which is infinate so i've set them to 20 which should be ok seeing as 29 = 20 mins, also turned the rear window down from 20 to 29. Will see how it goes, although with the heated rear window set at 29 i've always had to turn it off manually cos it stay on far too long.
