This is a discussion on *Urgent* Fabia dashpod been unplugged...help :) within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Friend of mine has unplugged his instrument cluster and having done a auto scan - the following log was generated... ...
| Ex Modder Join Date: May 2005 Location: Blackpool.
Members Car: Omega 2.5 V6 CDX Auto Images: 2 Thanks: 93
| *Urgent* Fabia dashpod been unplugged...help :) Friend of mine has unplugged his instrument cluster and having done a auto scan - the following log was generated... VAG-COM Version: Release 311.2-N Chassis Type: 6Y - Skoda Fabia Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69 Address 01 ------------------------------------------------------- Controller: 038 906 019 LA Component: 1,9l R4 EDC 0000SG 5405 Coding: 00102 Shop #: WSC 13765 TMBWU46Y644030802 SKZ7Z0D2329722 3 Faults Found: 19586 - EGR System Regulation Range Exceeded P3130 - 35-10 - - - Intermittent 18058 - Powertrain Data Bus: Missing Message from Instrument Cluster P1650 - 35-10 - - - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 6Q0 907 379 H Component: ABS/ASR 5.7 FRONT V40 Coding: 00188 Shop #: WSC 13765 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications Address 08 ------------------------------------------------------- Controller: 6Y0 820 045 Component: Klimaanlage X0830 2 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 79-00 - Please Check Fault Codes 01317 - Control Module in Instrument Cluster (J285) 79-00 - Please Check Fault Codes Address 09 ------------------------------------------------------- Controller: 6Q1 937 049 D Component: 0000 BN-SG. 1S34 Coding: 25738 Shop #: WSC 13765 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications Skipping Address 15-Airbags Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: 0037 GATEWAY CAN 1S34 Coding: 00014 Shop #: WSC 13765 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications Address 44 ------------------------------------------------------- Controller: 6Q0 423 156 AB Component: LenkhilfeTRW V270 Coding: 10120 Shop #: WSC 13765 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 6Q0 959 433 E Component: 33 Komfortgerát 0002 Coding: 00066 Shop #: WSC 13765 1 Fault Found: 01312 - Powertrain Data Bus 79-00 - Please Check Fault Codes End ------------------------------------------------------- How do I fix his car please ![]() Thanks. |
| | #2 | |
| Ding, dong Join Date: Sep 2003 Location: in the doghouse
Images: 4 Thanks: 6
| Re: *Urgent* Fabia dashpod been unplugged...help :) i'd say tou need to double check that it was plugged back in, and it it was, then i'd look at the wires
__________________ Jeff: Ambitious, but rubbish Quote:
Members Car: Audi S3 Thanks: 195
| Re: *Urgent* Fabia dashpod been unplugged...help :) Those plugs are a little fiddly. If the codes don't clear then check it is properly plugged in and it should clear ok.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| | #4 | |
| Re: *Urgent* Fabia dashpod been unplugged...help :) Quote:
He read this and sorted himself cheers guys - it was the wiring. Now his key won't lock his car remotely, although it will start it. Any ideas? | |
| Re: *Urgent* Fabia dashpod been unplugged...help :) if he has the second key shouldn't be a problem - Fabia-vrs.com - Key Coding Follow the bit about coding fobs.
| Re: *Urgent* Fabia dashpod been unplugged...help :) Thanks Stu |
| FS Brand new Fabia vRS Dashpod | Bigw2069 | Items for Sale | 1 | 02-12-2008 20:07 |
| ECU coding to dashpod | Shifty | Maintenance & Performance | 6 | 05-07-2008 09:38 |
| Help coding new fabia vrs dashpod | jmd | Diagnostics & VAG-COM | 17 | 14-03-2008 22:51 |
| Felicia, 1.3mpi, '99. - 'something' unplugged | lajonel | Favorit, Felicia, Fun and Forman | 6 | 05-08-2006 07:32 |
