This is a discussion on VAG-com code needed quickly! within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; I havn't had a chance to do a search, sorry. But I need the code for ONE beep on door ...
| Naughty Pix! Join Date: Dec 2004 Location: Writing in these boxes is soooo last year!
Members Car: 06 Fabia vrs Thanks: 128
| I havn't had a chance to do a search, sorry. But I need the code for ONE beep on door LOCKING via the remote key. I spoke to the *cough* Skoda tech and they don't have a clue what I'm going on about when I tell them about using the VAG com for enabling different functions. My car will be ready shortly as I saw it in the workshop when I drove past about 20 minutes ago. If they couldn't find out what to do I would like to be able to give them the code and the procedure. Meanwhile, I'm off to contact a mainland estate agent ![]()
__________________ |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 67
| Re: VAG-com code needed quickly! I found this info on VRStu's excellent website here. Is that what you need? If other settings are available they should be visible by scrolling through the various Channels. ANTI HIJACK [Select] [46 - Cent. Conv.] (35 - Cent. Locking for manual window cars) [Adaptation - 10] Channel 03 to 08 (Depending Options Below) Adaptation Value (1 = on, 0 = off) [Save] Channel 03 Auto Lock Channel 04 Auto Unlock Channel 05 Unlock, horn sounds Channel 06 Lock, horn sounds Channel 07 Unlock, turn signals flash Channel 08 Lock, turn signals flash Remember to do a scan of the module on each one to find out what each channel is, prior to making any changes as some cars beep is channel 7, not channel 6.
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.12mpg... Last edited by DGW; 16-06-2006 at 14:43. |
| Re: VAG-com code needed quickly! I looked on Stu's site before posting this thread, but I wasn't sure if those codes you list are the ones? Where it was under Anti hijack, I left it alone. Also it describes a 'horn' sound. I don't want my horn to go off when I lock my car Oh God, maybe I should leave well alone ![]()
Members Car: 2004 Fabia vRS TDI PD130 Thanks: 21
| Re: VAG-com code needed quickly! The horn sound is the beep. So you want channel 06 setting to 1.
__________________ John His Slow Black Diesel Powered Hatchback Hers Full Fat HotHatch with Cup suspension and spolier kit |
| Re: VAG-com code needed quickly! Thanks
| Re: VAG-com code needed quickly! I ended up ringing Skoda UK to confirm it could be done as my dealer said it wasn't in his manuel Anyway, they were fantastic and gave me the name of the guy in the technical department who was happy to talk my local techs through it. I now have one beep on locking it didn't cost me anything though ![]()
