vagcom laptop question
This is a discussion on vagcom laptop question within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Ive acquired a laptop to use just for vagcom purposes. The battery however is completely flat. The laptop will stay ...
Old 06-05-2008, 17:22   #1
Adamhodg's Avatar
Default vagcom laptop question
Ive acquired a laptop to use just for vagcom purposes. The battery however is completely flat. The laptop will stay on but wont charge the battery. It will only work when connected to the mains. My question is is can i connect the laptop to the mains and plug it into my car without everything blowing up lol?
Adamhodg is offline
Old 06-05-2008, 17:43   #2
Why So Serious
fatty5000's Avatar
Default Re: vagcom laptop question
Yes
It sounds like your battery is dead on the laptop.
You may be able to get a cheap replacement but they do tend to be a pricey.
HTH
fatty5000 is offline
Old 06-05-2008, 18:02   #3
VRSPhil's Avatar
You can plug the laptop into the mains, but you must NOT charge it via a car charger which is plugged into the car you're scanning.
Octavia vRS WRC
VRSPhil is offline
Old 06-05-2008, 18:08   #4
Adamhodg's Avatar
Thanks for your replies
Very much appreciated!.
Adamhodg is offline
Old 06-05-2008, 18:51   #5
Ex-Moddy
Makefish's Avatar
Just to confirm what you already know in that you are fine to use laptop whilst plugged into the mains but I had the same issue as you in that the battery refused to charge! I purchased a replacement refibished battery from ebay and all is now OK
Black magic Octy II vRS MY2008 with Maxidot ~ Xenons ~ Cruise ~ Light Assist ~ Dual Zone Climate Control ~ Rain Sensing Wipers ~ MFD2 Satellite Navigation ~ VAG Bluetooth Phone Kit ~ Milltek Exhaust with 2.75" Downpipe ~ EVOM Ram Air Intake ~ Nuespeed Shortshifter ~ Eibach Rear ARB ~ Koni FSD Dampers ~ Eibach Springs ~ Forge Front Mounted Twintercooler ~ Nuespeed Hi-Flo Intercooler Pipe ~ Nuespeed Hi-Flo Turbo Outlet Pipe ~ Eurojet PCV Valve ~ Forge DV ~Autotech Hi Volume Fuel Pump ~ Nuespeed Torque Arm Insert ~ NGK Iridium Spark plugs ~ REVO Stage II+ Software ~ Matt Black Viper Stripes!
Makefish is online now
Old 20-05-2008, 16:50   #6
pdhealy's Avatar
Excuse my ignorance, but why not?
Dear Lord.. The gods have been good to me. For the first time in my life,
everything is absolutely perfect just the way it is. So here's the deal: You
freeze everything the way it is, and I won't ask for anything more. If that
is OK, please give me absolutely no sign. OK, deal.
pdhealy is offline
Old 20-05-2008, 17:27   #7
BRISKODA Staff
mannyo's Avatar
Drain on the car battery. VAG-COM is used when the engine is switched off. The power required to run a laptop is quiet high. If the voltage drops below a certain level then the ECU will lockout and no changes will be able to be written. This is to protect the ECU from becoming corrupted.
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is online now
Old 21-05-2008, 10:16   #8
pdhealy's Avatar
Thanks for that.
If the car is running, can it be used?
pdhealy is offline
