40,620 Members 1,518,541 Posts
01309 error code Power Steering FABIA
This is a discussion on 01309 error code Power Steering FABIA within the Fabia I forums, part of the Skoda Model Discussion Area category; I've got no power steering . Thanks for the help so far from everybody , changed the angle sensor. Got ...
Old 31-01-2008, 22:18   #1
smudge's Avatar
Members Car: Octavia
I've got no power steering . Thanks for the help so far from everybody , changed the angle sensor. Got Vag com working ( EBAY version , interface must be plugged in for it to work, use a com port , so instructions a bit wrong) but I have 01309 Power Steering control module(j500) , 49-00 - N0 Communications which returns as soon as i clear it.
Angle sensor = no fault codes
I've found out from this forum that the pump has the ecu fitted within it ( please correct me if I'm wrong ) and can be acessed from behind the grill beside the passenger near side fog lamp.
Looking at the cables through the removed grill, Left hand side data coms bus , middle is main power and right hand side is the angle sensor.
So can any body help with these questions.
Can the ecu be seperated from the pump for inspection?
Is the large brown cable ground and where grounds onto the chassis?
Any idea where the com cable goes as maybe i could check the other side.
Any other ideas
Did have these cables unplugged and found a bit of dampness within them , maybe there is water in the ecu.
Thanks to everyone who's helped so far , but I need just a little more.
smudge is offline
Old 19-04-2008, 17:34   #2
smudge's Avatar
Re: 01309 error code Power Steering FABIA
An update.
My fault is no power steering on start up with warning light , 99% of the time . 1% of start ups , no warning light . Power steering is fully functional.
I've already changed the angle sensor to no avail and now I've taken off the pump.
Has any body taken one of these apart as I'm convinced its corrosion inside across the PCB of the ECU (?) .why else would it work sometimes.
Can any body tell me what make this pump is ? So far I have a quote of £360 +VAt for a new one. Indentification based on my engine code.
Thanks
Smudge
smudge is offline
Old 19-04-2008, 18:23   #3
Duggie's Avatar
Members Car: Skoda Fabia 1.4 MPI
This is worrying, my light sometimes comes on when the engine is started, then goes out.... ehhrrmmm.
Dream as if you'll live forever, live as if you'll die today. Jabbasport rear ARB... (HELL YEAH) Weitec V1 coilovers. Vrs 16' Alloy Wheels. Forge Front Strut Brace. Sidestrips off. Colour coded front grille. Alpine IVA-D105R headunit twinned with a Novex bandpass sub enclosure 2X12 inch subs and a Fusion 1000W amp. Hornet Maxx1 auto alarm.
Duggie is offline
Old 15-06-2008, 09:35   #4
smudge's Avatar
It was the pump. fitted 2nd hand and cleared codes with vag-com all ok now
smudge is offline
Old 15-06-2008, 10:40   #5
BoilingPoint's Avatar
What did the 2nd hand pump cost you mate...
Fabia ... Gone but not forgotten...
BoilingPoint is offline
Old 15-06-2008, 12:44   #6
smudge's Avatar
£200 . I was lucky to find one on Ebay from a 2001 car. Mine is 2000. Worked ok though .
smudge is offline
Old 15-06-2008, 16:45   #7
Thanks... Big saving on new then.
Similar Threads
01309 - Power Steering Control Module Joey122mac Fabia I 38 04-01-2009 17:59
Power steering fault - fault code 01288 - is this the normal plastic sensor fault? mgskoda Diagnostics & VAG-COM 6 05-11-2007 19:31
What does 06-10 mean after the fault code 01288? (power steering problems) mgskoda Diagnostics & VAG-COM 4 06-08-2007 19:44
Octavia 4X4 with 00778 error code (steering sensor) stringman Octavia I 15 26-07-2006 20:41
Error code help Gandalf Diagnostics & VAG-COM 4 19-07-2005 13:18
