This is a discussion on 01309 - Power Steering Control Module within the Fabia I forums, part of the Skoda Model Discussion Area category; Just VAG-COM'd my car and I got the following messaege: 01309 - Power Steering Control Module - J500 - 49-00 ...
| Briskodian | 01309 - Power Steering Control Module Just VAG-COM'd my car and I got the following messaege: 01309 - Power Steering Control Module - J500 - 49-00 No Communication The power steering does not work - Its a 1.4 MPI Fabia - 2000 model . I ve had the power steering pump replaced (suggested by a few on this forum) and this fault code is still present. Anybody have any ideas what could possibly be wrong? |
| Briskodian | Re: 01309 - Power Steering Control Module steering rack or angle sensor?
__________________ 2001 FANTASY GREEN SKODA FABIA F.T.M |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: 01309 - Power Steering Control Module ![]() Was it a known good pump? |
| Briskodian | Re: 01309 - Power Steering Control Module my 2000 1.4 fabia (petrol) power steering intermittantly stops working. When i had a long journey the pas warning light came on . I stopped the car turned the ignition off then on and it went out, the lights still flicker sometimes and dont trust the steering sometimes. Sorry im no mechanic seems could be a design fault and if so shouldnt skoda put it right for free? battery and alternator tested and are ok |
| | #5 | |
| Re: 01309 - Power Steering Control Module Quote:
| Briskodian | Re: 01309 - Power Steering Control Module It was a good pump - At least I pretty sure it was... ![]() Is there any way of testing a pump? Is there any electirc switches on the way that could lead to this problem? This problem started after a window got smashed, the battery went flat and was jump started ..... Any way of repairing this> |
| Briskodian | Re: 01309 - Power Steering Control Module By reapiring this I mean the power steering - I ve tried pretty much everthing - Fuses / etc I just want to try and gett his repaired as I think the Fabia is a great litte car and want to use it more often .... Ideas?....... |
| Briskodian Join Date: Aug 2003 Location: High Wycombe, Bucks
Members Car: 1993 Subaru Legacy turbo. Thanks: 0
| Re: 01309 - Power Steering Control Module My Father in Laws car has an intermittent power steering problem too. The car is a 2000 1.4 8 valve Fabia. The problem started just before the battery died and although the car has a new battery now sometimes at the end of a journey it doesn't work. Where is this sensor that could be at fault please? I checked the book last night and there was no fuse listed for the system. Thanks ![]() |
| Re: 01309 - Power Steering Control Module There are two fuses for the PAS system. The sensor is mentioned in great detail elsewhere on the site. The PAS ECU which is part of the pump has a couple of supply lives, an earth, the PAS Sensor and its wires and a set of communication cables, that is it. No additional switches. |
| | #10 | |
Any faults in any other systems? | |
| | #11 | |
| Briskodian | Re: 01309 - Power Steering Control Module Quote:
We checked the electrics pane in VAG -COM - Not sure if that answered your question regariding PAS controller... Yes there was two other fault code although I think its nothing to worry about but ... 01135 - Interior monitoring sensor - 36 -10 Open circut intermittent 01136 - DataBus for comfort system - Single ......(rest not written down ) | |
| | #12 | |
Any way of testing these pumps - electric getting to the pump. I ve isolated the fact that it is not the pump .... Whats the next step if any .../? Thanks - Help appreciated ![]() | |
| | #13 |
| Re: 01309 - Power Steering Control Module Hmm you have a single wire fault there on the data bus, I would check to see if anything else is in single wire. You can check to see id the power and earth are ok at the pump with a multi meter. |
| | #14 | |
Wondering how I caould check this .... | |
| | #15 |
| Briskodian | Re: 01309 - Power Steering Control Module Ok understand how to check for power and earth are ok at the pump. How to check if anything is in single wire |
| | #16 |
| Re: 01309 - Power Steering Control Module The left and plug as you look at it though the grill is the communiction plug, the large centre one is power etc and the PAS sensor is the right one. |
| | #17 |
| Briskodian Join Date: Aug 2006
Members Car: SEAT Cordoba SE TDI PD130 Thanks: 9
| Re: 01309 - Power Steering Control Module I'm suffering from a similar problem: Mine has suddenly stopped working, without warning today. No intermittant fault, just no power steering from startup. Tried re-starting etc to no avail. Has been fine until now. Vag Com says no communication to the module, same as the first post in this thread. Tried a new fuse (fuse 7 based on the diagram on Fabia-vrs.com - Fuse Panel Layout but the fuse was fine) But you say there are two fuses? Where might the other one be? Just had a look behind the grille to see if I can access the ECU but the horn is in the way. It will have to wait till tomorrow before I can have another look. Damn the steering is heavy with no PAS! :o |
| | #18 |
| Briskodian | Re: 01309 - Power Steering Control Module You get used to the hevy steering - Its been with me for months |
| | #19 |
| Re: 01309 - Power Steering Control Module You've still not sorted it? It's lucky I was using my polo until today. No power steering on that so I'm used to heavy steering. Even so, this thing is in a league of it's own! |
| | #20 | |
| | #21 |
| Briskodian | Re: 01309 - Power Steering Control Module No - I had these problems when my window got smashed and the battery ran out. Can you think of anything that might have caused it on your car. I actually replaced the pump from a 55 plate scrap car and guess what - That didnt help |
| | #22 |
| Re: 01309 - Power Steering Control Module I replaced the battery around christmas time because after five and a half years and 93000 miles, the original one had had it. But Ive done about 2000 miles since then without a hitch. I've just ordered a fabia haynes (been meaning to for a while) To see if I can find where this other fuse is. |
| | #23 |
| Re: 01309 - Power Steering Control Module Found your thread saying the other fuse is on top of the battery. Had a look at it, cleaned the contacts and the fault still remains. I will have to check continuity of the wires now, otherwise it's new ECU. ![]() |
| | #24 |
| Re: 01309 - Power Steering Control Module Right I just checked the Power Steering fluid and the level is on minimum. If the power steering motor is buggered, would this mean that the power connection to the ECU becomes severed? |
| | #25 |
| Re: 01309 - Power Steering Control Module Topped the fluid up and it's made no difference. Cant get the plugs out of the module so Will have to take the bumper off, tomorrow now as the weather has turned. |
