This is a discussion on 02 Fabia 1.4 16v Engine Warning Light within the Fabia I forums, part of the Skoda Model Discussion Area category; Hello All - Need some advice! I've had this Fabia for a few weeks and I was just coming round ...
| Briskodian | 02 Fabia 1.4 16v Engine Warning Light Hello All - Need some advice! I've had this Fabia for a few weeks and I was just coming round to the idea that its not a bad little motor, when the engine light came on. I drove for ten miles this morning (damp,wet & foggy) with no problem, then after stopping and restarting, the light has stayed on. The car appears to run normally although the tickover was a bit wavery this morning. Looking thro' the forums it looks like this light comes on at the drop of a hat and there's no way of knowing wether its a passing glitch or a serious problem without access to a code reader - does this light ever reset itself? Do these lights appear as often as it appears they do and is it worth buying one of the reader/reset tools just in case? I hate going to dealers (sorry to the good ones out there) and would rather buy the kit if its worth it. Regards Andy |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light All levels seem ok Andy |
| Techie Teacher Join Date: Jun 2004 Location: Hertfordshire
Members Car: VW Golf TDI SE 5door Thanks: 2
| Re: 02 Fabia 1.4 16v Engine Warning Light I think the most likely thing for it to be is a lambda sensor but that light shows for so many different things. When it was showing on my car it was generating various codes and they ended up looking at the ECU, the brake switch, the ABS control unit and pump and even the wiring loom. I always found the engine light came on with the EPC light but that the EPC would go off after a restart followed by the engine light a day or so later (so before I could get to a garage). Fortunately the system does store fault codes until it is cleared by a vag-com system. You just have to hope the code makes sense to whoever reads it as the first one it showed on mine made the dealer ask if it was an automatic!
__________________ Neil Williams History: Fabia 1.4 8v, Fabia 1.4 16v, Fabia vRS Now driving a Golf Mk5 tdi Teachers click HERE for free resources. |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light so is it not unusual for this light to come on? the car appears to be running as normal - will it be ok to use it for a while until I can get it tested? cheers Andy |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: 02 Fabia 1.4 16v Engine Warning Light Could be quite a few things on the 1.4 16v, my bet will be either an EGR fault or MAP sensor. Both caused by the same fault with the engine. Whats the oil consumption like? |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light Thanks Lummox, I'm new to engine electronics so what's an EGR fault and map sensor? I haven't had the car long so I can't say what the oil consumption is like, although it was on the bottom when I bought it. I did change the oil recently(being careful not to over fill it). What do you recon to these plug in fault code finders? cheers Andy |
| Briskodian Join Date: Dec 2002 Location: Norwich
Members Car: Fabia VRS and Elegance Thanks: 0
| Re: 02 Fabia 1.4 16v Engine Warning Light Happened on my 1.4 16v, and the car drove normally, turned out to be the lambda sensor.
__________________ 2005 Fabia VRS - Lemon Yellow - JabbaSport Custom Remap, JabbaSport ARB, Sachs Uprated Organic Clutch, Eibach Pro Dampers and Lowering Springs, PD160 Air Intake and Green Stuff Filter, Forge FMIC, Front Strut Brace, 312mm brakes, Renault Aero Wipers, Cupholder. 2004 Fabia 1.4 16v Elegance - grey - standard, except for the addition of a cup holder and some mudflaps...oh, and some 15 inch alloys. |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light where is the lambda sensor - is it usually on the ex. downpipe / manifold somewhere? Andy |
| | #10 |
| Re: 02 Fabia 1.4 16v Engine Warning Light Pop the engine cover off and have a look in the throttle body, is it clean? |
| | #11 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light Hi Lummox, its' not exactly clean - theres's some brown staining on the throttle body and a little soft brown deposit on the back of the throttle valve. I've felt up inside the airbox and there's some greasy deposit (but not lots of oil)in there as well. Andy |
| | #12 |
| Re: 02 Fabia 1.4 16v Engine Warning Light Doesnt sound to bad then. If its not injesting alot of oill id say as mentioned it could well be the lambda probe. But its all guess work until the codes are read off. |
| | #13 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light Thanks - I'll try not to panic until I get it tested. Was you thinking of blowby / high crankcase pressure leading to clogged up emissions kit? Andy |
| | #14 |
| Re: 02 Fabia 1.4 16v Engine Warning Light blowby is a known issue on them yes. It clogs up the inlet manifold and associated sensors with oil. |
| | #15 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light Hello Lummox, I've bought one of those e-bay code readers - here's what came off: (4497) - 17559 - Bank 1 mixture region 1 below lean limit (4192) - 16786 - EGR flow excessive (0214) - 00532 - Supply voltage (I think this one was off the airbag or ABS tho') I dont know what to make of the first one , What about the egr valve? The unit has removed the codes and the light's gone off - for now. Do all of the codes stored bring on the engine light? Cheers Andy |
| | #16 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light Andy, I have had code 16786 repeatedly and also 17559 which do trigger the engine light. I have deleted the codes but they come back after a couple of days. Have you managed to solve this? Thanks Andy. |
| | #17 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light only by getting rid of the car! ![]() i believe the 16v 1.4 has quite an apetite for oil - mine was no exception although within limits in handbook the oil gets burnt, which in turn clogs up the egr valve. andy |
| | #18 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light Can you remember what the engine code (model type) was as I'm getting a bit concerned! |
| | #19 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light mine was the 1.4 AUB 100bhp I think. As far as i remember the handbook said something like up to 1 litre in 1000kms for oil consumption was acceptable - which is a hell of a lot of oil to be burning. mine wasn't as bad as that but bad enough. i'm working on memory here as I sold the car over a year ago. Andy |
| | #20 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light I'm no mechanic but my fabia 1.4 8v has the same prob, was told by garage it can come on for the slitest thing damp in exhaust being one. ECR light come on then never showed again as does engine light then may not come on for monthsso God knows!!!!!!!!!!!!! |
| | #21 |
| Briskodian | Re: 02 Fabia 1.4 16v Engine Warning Light Mine does it and then it goes out again never seems to cause any problems driving wise tho. 1.4 8v 2001 model classic ie no toys whatsoever |
