This is a discussion on 02 Fabia 1.4 8v, 90k miles... advice within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi all, It's great to have found this wonderful forum full of Skoda owners and plenty of advice. I have ...
| Briskodian | 02 Fabia 1.4 8v, 90k miles... advice Hi all, It's great to have found this wonderful forum full of Skoda owners and plenty of advice. I have a few niggles on my car, questions about servicing etc that I'd like to ask. Please be patient with me as I am in the main, clueless about the internals of cars and can top up oil, coolant, and change a tyre ![]() Firstly, I have an 02 Fabia, 1.48v Classic, now just over 90k miles. Is servicing at Skoda garages worth it? I only had services there whilst still in warranty, and now have just moved to an independent, should I switch back? As far as I'm aware, previous servicing has not swapped anything of importance out, other than the usual wear and tear items - tyres, brakes (pads + discs), filters etc... Are there any major service things I should have undergone by the time I've reached 90k miles and 5 years ownership? (I have chain instead of belt, so I assume that's fine)... Aircon - has not been serviced, does that need servicing after 90k? Brakes - I wonder if this is my driving style... but I find on a few too many occasions for my liking, the wheels lock, my wife also drives the car and hasn't had any complaints... I'll describe what happens I brake hard, the wheels lock, but just before they do, I get the "kick back" of the brake pedal against my foot before they lock and I get the ABS light flashing on the dashboard.. I assume this is the ABS coping somewhat but then failing? I have to remove foot from brake and then reapply to continue braking... Is this something I need to get looked at? Temperature gauge Coolant level is fine. About 6 months ago, I had experience similar to others which I've noted on here - temperature gauge would only work every 1 in 3 journies or so and generally would continue working if engine was turned off and then on again... This then continued, but now temperature gauge warning light would come on... However if I drove for around 10 mins, then switched engine off / on... temperature light would not come on and temperature would be as normal... These days, temperature warning light comes on every journey, temperature gauge appears to operate fine, coolant level is fine... I'm now a bit worried that I should get this looked at. What do you think likely causes are? Thanks James |
Members Car: '97R BMW 328i Saloon Thanks: 728
| Re: 02 Fabia 1.4 8v, 90k miles... advice A new temperature sender is a few quid - and a doddle to change, so thats worth doing for sure, as well as a coolant change with G12+. The cooling systems can be a touch fragile on these engines, so its worth looking after them. Yep, chain is fine. Brakes - worth seeing if any fault codes are being thrown. Do you know anyone who has VAGCOM? If not it may be worth saying where in the country you are - a fellow Briskodian may help for beer tokens. I found the ABS on the Fabia to be a bit oversensitive, but you should feel it working.Does the air con work? If so then I wouldn't worry about it. But if its a bit weak, or pongy, then get it serviced. I think VW do a full a/c service for under a hundred quid - bit of a bargain and IIRC they make a loss on every one.
| | #3 | |||||
Members Car: Black Magic Fabia vRS Thanks: 387
| Re: 02 Fabia 1.4 8v, 90k miles... advice Quote:
Brake fluid and coolant should be replaced every two or three years I think (two if I recall correctly), to avoid the risk of the insides of you engine / brake system rusting up.Quote:
You can buy kits for topping up the refrigerant, but it's as cheap to get it done professionally. As for the sensor, more details are here. I don't have any personal experience of the flap motors, but there's plenty of info on here if you have a search. But as I say, if it seems OK, it probably is! Quote:
Hope this helps!
__________________ | |||||
