This is a discussion on 04 vRS gearing / speeds within the Fabia I forums, part of the Skoda Model Discussion Area category; Hullo Can someone with a Fabia vRS of this year please stick up your usual speeds at various RPMs in ...
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| 04 vRS gearing / speeds Hullo Can someone with a Fabia vRS of this year please stick up your usual speeds at various RPMs in sixth, please? ![]() Thanks. Just wanted to get a little taster and see if I'll get better cruising economy in theory. ![]() I need like 40mph/60mph/70mph/80mph+
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! |
| Briskodian Join Date: Apr 2005 Location: Aberdeen, Scotland
Members Car: Black Magic Fabia vRS Thanks: 0
| I can stick mine in 6th at 25mph, remove both feet from pedals, and watch it slowly pull up to 30mph bang on and it would sit there all day on relitivly flat road surface ![]()
__________________ Old car :- 2005 Black Magic Fabia vRS - Eibachs,Star Performance Re-map New Car :- Renaultsport Clio 182 c/w Cup suspension pack and Cup spoiler pack |
| | #3 | |
| Briskodian Join Date: Jan 2005 Location: I'm a monkey from outer space, woooooooo ahhhhhhhhh hehe hooohaa
Members Car: None Thanks: 0
| Quote:
__________________ Sunlight Silver MX-5 1.8 Sport | |
| | #4 | |
| Quote:
__________________ Old car :- 2005 Black Magic Fabia vRS - Eibachs,Star Performance Re-map New Car :- Renaultsport Clio 182 c/w Cup suspension pack and Cup spoiler pack | |
| Yeah, mine pulls to the tickover from 25mph in fifth too, although only on the flat and I try not to do that too often. I just wondered what sort of RPM 80mph would be - Currently its 2500rpm in fifth in my car, and I'd like it to be somewhere a lot closer to 2000rpm after the work is done.
| Actually just read your topic name correctly, mine is an '05. Dont know if that would make any difference? ![]()
| | #7 | |
| Quote:
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! | |
| | #8 | |
| Quote:
| Briskodian Join Date: Oct 2003 Location: Cheshire
Members Car: '05 Fabia vRS Thanks: 0
__________________ '05 Diamond Silver Fabia v/RS |
| | #10 | |
| Quote:
| | #11 |
| Looks like the 04 doesn't rev much lower in sixth at 80, than mine does now in 5th - only around 100rpm or so. Not so good, but still. ![]() edit: Obvious Q now is, which may have been asked before, is WHY did they change it to a shorter ratio box? ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! Last edited by devonutopia; 03-06-2005 at 23:32. |
| | #12 |
| Briskodian Join Date: Feb 2004 Location: Warwick
Members Car: BMW Z4 Coupe Thanks: 0
| My '04 gearbox gives me 70mph at just under 1900 rpm. I can't remember the exact figure, but it is not much above 2100rpm at 80mph. Will check this afternoon.
__________________ Dave ![]() Ex - Fabia VRS Owner Now Z4 Coupe |
| | #13 | |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Quote:
The idea of the six speed box is not to change the rpm in final gear. It brings all the lower gears closer together. | |
| | #14 |
| Briskodian | Fabia RS - Modified gearbox The gearbox combined with the 1.9TDI/ 96 kW engine will have the gear ratios optimized and, consequently, some of its spec will change slightly (see the following table). Valid from: Week 5, 2004 1.9 TDI/ 96 kW 1.9 TDI/ 96 kW Old New Gear ratio I. 3.769 3.769 II. 2.087 2.087 III. 1.324 1.324 IV. 0.911 0.977 V. 0.902 0.975 VI. 0.756 0.814 R 4.459 4.459 Final ratio I-3.238/ II-2.615 I-3.238/ II-2.615 Max speed kmh 204 206 Acceleration 0-100 kmh s 9.6 9.5 Fuel consumpti on EU 3 EU 3 A (urban) l/100 km 6.7 7.1 B (extra-urban) 4.2 4.5 C (total) 5.1 5.4 CO2 (total) g/km 138 146 |
| | #15 | |
| Quote:
__________________ Dave ![]() Ex - Fabia VRS Owner Now Z4 Coupe | |
| | #16 |
| Oh good. Lets hope I have this same gearbox then. ![]() Will be nice to have 400 less RPM at 80mph.
| | #17 |
| Just checked my 2005. 2400rpm in 6th at 80mph ![]()
| | #18 |
| Briskodian | My 04 was the same as yours Jobo roughly. About 2200 or slightly less at 70. |
| | #19 | |
| Briskodian Join Date: Oct 2004 Location: Gloucester
Members Car: Fabia vRS Thanks: 14
| Quote:
__________________ David - Skoda Fabia vRS - October 2004 facelift | |
| | #20 |
| An early car doing 2400rpm in 6th would be going at over 91mph - or at 78mph would only be turning at 2050rpm....
| | #21 |
| Sounds like I'm in for a gamble which gearbox I have. ![]() Anyone know both part numbers for the two generations of gearbox so I can see which mine is, and be prepared. It doesn't really matter, but would be nice to know. I prefer longer gearboxes anyway, but won't mind if I have the closer ratio one.
| | #22 | |
| Fabian | Quote:
ETKA lists three 6-speed gearboxes, with codes FJW, FSM and HDS. My Furby vRS was built in June '04 and has the newer gearbox, code HDS. I guess the F-series were earlier, but whether one or both refers to the early 'long-legged' gearbox, I don't know. (I don't know what the difference between the FJW and FSM boxes was.) So the '04 gearbox on the spreadsheet refers to the HDS; the '53 gearbox data will be for the F-series, I guess. | |
| | #23 | |
| Quote:
| | #24 |
| Briskodian | Who needs 6 gears with all of that torque. I think it would be good to have a higher 5th gear on my pd100 after Allards get their hands on it on Friday. John |
| National Briskoda Trackday | delcac | Shows | 410 | 12-03-2004 15:21 |
