This is a discussion on 1.4 16v EGR question within the Fabia I forums, part of the Skoda Model Discussion Area category; I haven't managed to find the answer to this on a search. The car is used mainly for town driving ...
| Briskodian | 1.4 16v EGR question I haven't managed to find the answer to this on a search. The car is used mainly for town driving with no probs. On the occasional 50+ Mile motorway journey, the engine management light comes on at the end or the day after. It goes off again after a couple of days town driving. In the absence of VAG COM, I have assumed that the EGR system is blocked or not functioning correctly. If it was O2 sensors I assume the light would stay on. I understand that the ECU 'samples' EGR flow rates on a steady throttle opening, hence town driving masks the fault. Nearly there.... I'm going to remove, clean/inspect EGR valve and pipe, if I disconnect or renew the EGR valve, do I need VAG COM to reset it to the car???? I think I do. Finished ![]() ![]() ps what is the price of a new valve?? |
| Briskodian | Re: 1.4 16v EGR question I'm sure that someone with more knowledge will answer later or tomorrow, but for now, if you are only removing a cleaning a complete assembly, ie don't totally strip it down, and don't try to run the engine etc while you have this assembly out, then there is not a problem. |
| The Following User Says Thank You to rum4mo For This Useful Post: | kwacka (27-09-2008) |
| Briskodian Join Date: Apr 2006 Location: North East
Members Car: Fabia 1.4 16V Comfort & Porsche 968 Coupe Thanks: 5
| Re: 1.4 16v EGR question It could be the heater in the front lambda sensor. That happened with mine. The heater is only required when the engine is cold and the car did not run right for the first couple of miles until the probe reached its operating temperature. The engine management light would go off after a couple of hot starts, but return after a cold one. How does your car run from cold?
__________________ My other car is a Porsche.... |
| Briskodian | Re: 1.4 16v EGR question The car runs perfectly, light on or off, hot or cold. The light has only come on twice after a long run, then goes off after a couple of days town driving. If it is EGR flow, I think it is only just out of spec, hence the initial attempt at cleaning (and it costs nowt). My deeper thoughts are that it could be the valve, but I don't know exactly how it works, or when it's supposed to open. Is it on/off or proportional?? I know it definitely isn't working when the engine is idling, but maybe that's right. I understand it can be checked on VAG COM, but I ain't got it. I did think of sensors as the car has done 76k miles, before I go down that road I will get it checked on VAG COM. Trying the easy stuff first. |
| Re: 1.4 16v EGR question I think that you are probably better off finding someone local to you with VAG COM and getting it scanned for fault codes, or buy one of the cheap hand held code readers off Ebay. It'll be cheaper than changing sensors that may or not be faulty.
| The Following User Says Thank You to ExAudiSi For This Useful Post: | kwacka (27-09-2008) |
| Briskodian | Re: 1.4 16v EGR question Thanks fellas, I might just leave for now (apart from clean it), the car does a long run once or twice a year so it's not that big a deal. I'm going to get VAG COM at some point anyway. |
| Woof! Join Date: Sep 2006 Location: From Leeds, Live in Swansea
Members Car: 2008 Fabia3 1.9Tdi Estate Images: 7 Thanks: 50
| Re: 1.4 16v EGR question Please correct me if im wrong, but th 1.4 16v doesnt have an EGR valve does it? I thought only turbocharged engines had EGR valves, being as they are exhaust gas recirculation valves, a non turbo'd engine wont need to recirculate exhaust gas will it. The 1.4 doesnt have a turbo does it. |
| Re: 1.4 16v EGR question The EGR is intended to reduce emissions and unfortunately, most modern engines have them whether turbo charged or not. The 1.4 16v certainly does have one.
| Re: 1.4 16v EGR question Ah well, consider me told, cheers. |
| | #10 |
| Briskodian | Re: 1.4 16v EGR question EGR faults on 1.4 16v!!??? i've changed countless amounts of these they do have a real problem, as for cleaning it i dunno how well that will work but by all means give it a go, off the top of my head ima not sure about the price of new ones think around th £100 mark for genuine and for needing vag com to turn off the light, it will reset itself automatically after it senses the flow rate is ok or so many ignition on off cycles, i wouldn't worry about resettin it after a replacement tbh mate |
| The Following User Says Thank You to techbob For This Useful Post: | kwacka (28-09-2008) |
| | #11 |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: 1.4 16v EGR question Either way assuming something isnt a good way to diagnose anything. Get it on VAG COM and verifiy the fault first. If it is EGR is could just be a blocked pipe. |
| | #12 |
| Briskodian | Re: 1.4 16v EGR question I know, I know, I'm waiting for the dollar to drop again so I can get a VAG COM lead from Ross Tech!!! Although I had made the assumption from reading plenty of threads on the subject of engine management light. As the light has gone out and the car isn't affected at all, I guess I'm being a bit lazy. |
| EGR fault on a 1.4 16v fabia | chrisw_vrs | Fabia I | 4 | 12-09-2008 20:09 |
| Egr valve in a 1.4 16v 101ps bbz engine | tripolitis | Fabia I | 7 | 10-09-2008 17:36 |
| 2001 Reg 1.4 16v Fabia- EGR Problems | Bev84 | Fabia II | 6 | 12-08-2008 23:00 |
| 1.4 16v fabia egr valve | raveon | Fabia I | 3 | 07-12-2007 21:56 |
