This is a discussion on 1.4 MPi coolant warning - why? within the Fabia I forums, part of the Skoda Model Discussion Area category; Hello all. We have just purchased a 52 plate Fabia 1.4 MPi (8 valve version) with 63K on the clock. ...
| Briskodian | 1.4 MPi coolant warning - why? Hello all. We have just purchased a 52 plate Fabia 1.4 MPi (8 valve version) with 63K on the clock. The one issue that has come to our attention that wasn't evident on the test drives is that the coolant level warning light (and audio) activates if the car is pointing forwards down a steep hill. The temperature guage on the dash shows temperature is fine and the coolant level is between the min/max markers on a level surface. We suspect there is jusy slightly too little liquid in the tank and so the sensor is triggered when the car is not level. I have travelled at least 200 miles in the vehicle since purchase and a steep downwards incline is the only instance where this happens. Does this sound plausible? We can't get to a dealer before next weekend but I do not wish to drive to/from work during the week if I am likely to be damaging the engine. Many thanks for looking.
__________________ Car: 2001 Fabia 1.9TDi with no modifications. Location: Blaydon-on-Tyne |
| Briskodian Join Date: Dec 2005 Location: Sawston, Cambridgeshire
Members Car: SKODA RAPID 136 Thanks: 20
| Re: 1.4 MPi coolant warning - why? If the car runs well, doesn't overheat and doesn't lose coolant I would agree with your diagnosis.
__________________ David McKinney TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN www.skoda-owners-club.org.uk |
| Off we go Mo Join Date: Dec 2003 Location: Sussex Coast
Members Car: 06 Fabia vRS Thanks: 5
| Re: 1.4 MPi coolant warning - why? Oooh I had this a while ago when my old Fabia vRS was parked on a hill *rummage on Briskoda* here's the thread: http://www.briskoda.net/forums/fabia...lashing/40449/ At the time the coolant was a bit low. |
| Briskodian | Re: 1.4 MPi coolant warning - why? Thanks for the reassurance. I just get nervous when I read in the manual not to drive the car with the temperature warning light on. As I say, though, the temp guage reads fine and the coolant level is between the lines on the flat. I'll top it up at the weekend when I can get to the dealer and will update the thread to let you know if it worked or not.
| coolant low on fabia 1.4 2000 model / no warning light / topping coolant up? | andrewaaa5 | Fabia I | 8 | 22-05-2007 08:40 |
| Engine coolant warning light | PSM | Octavia I | 3 | 03-04-2007 13:02 |
| Very Slight Coolant Loss - 1.4 MPI - Concerned? | Joey122mac | Fabia I | 9 | 06-02-2007 18:15 |
| Coolant warning | salmac | Octavia II | 1 | 06-04-2005 09:40 |
| Coolant warning light comes on in morning.... | Niche Market | Maintenance & Performance | 22 | 24-12-2004 00:56 |
