This is a discussion on 1.4 TDI PD 3 Cylinder Chip Tuning Help... within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi all, I want to chip tune my 1.4 TDI, I already have one of these resistor mods: http://cgi.ebay.co.uk/PD-TDI-TUNING-...QQcmdZViewItem It ...
| Briskodian | Hi all, I want to chip tune my 1.4 TDI, I already have one of these resistor mods: http://cgi.ebay.co.uk/PD-TDI-TUNING-...QQcmdZViewItem It reckons I will now achieve 90bhp + and extra 40nm of torque, I am not so sure? However I can confirm a massive improvement, thing is I want more power on the cheap, is this possible? I know Jabba do a chip to take power to 115BHP + 200lb/ft of torque, however I feel it is rather expensive? Is there another cheaper plug and play alternative? Jabba also chip ECU's by post but this means no rolling road setup, is this necessary? Please advise of your expreiences and problems encountered... Thanks, Pietch Last edited by pietch; 11-08-2005 at 13:28. Reason: Typo |
Members Car: Fiat Panda Thanks: 16
| Instead of your resistor mod, you could look at a Digital tuning box, made by someone like Dragon (check out www.mrhoot.com) which is about half the cost of a full remap, but almost as good ![]() Chris
| Briskodian | Mrhoot.com is just the resistor mod in disguise. The digital one is for the 1.9 TDI only Can I install a manual boost controller or bleed valve (along with a boost gauge of course). Is this poss? Thanks Last edited by pietch; 11-08-2005 at 13:58. |
| Briskodian Join Date: May 2005 Location: North East UK, Gateshead
Members Car: Red 2005 Fabia vRS Thanks: 0
| The ECU will most likely throw up some alarms if you put a boost controller or bleed valve on.
__________________ ![]() Vorsprung DERV Technik |
| Briskodian Join Date: Jan 2004 Location: North East England
Members Car: SEAT Leon TDI Sport Thanks: 34
| A remap or chip will get you a little more power but not much compared with a box. More power on the cheap isn't easy! ![]() A generic chip is fine if you don't have another mods, where as a custom map set up on the rollers will take advantage of them. The biggest difference between these & a box, is that it will be a much smoother power delivery & a custom remap will give you a choice of how you want it mapping. Jabbasport are probably the cheapest, especially with the Group Buys popping up from time to time. Also have a look at Custom Code, Forge Motorsport, Upsolute or Revo.
__________________ Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille. Also driving around in a Mini ONE that thinks it's a Cooper! John Cooper Works airbox, Superchips Bluefin remap, Sprint Booster, 17" Cooper S Spokes Last edited by Jon TDI; 11-08-2005 at 20:55. Reason: Didn't realise it was a resistor not a box! |
| Briskodian Join Date: May 2005 Location: Finland
Members Car: VW Polo 1.4 TDI Thanks: 0
| Have you already fitted the cupra intake (you should also remove trumpet from upper half of airbox and snowscreen below filter to make full use of it), helps with a box (or resistor mod) to cut smoke/improve performance if you turn the fuel delivery a bit higher.. I recon you can't get much more with a standard chip as the GT15 turbo can't take much more boost.. If you want more power than with box better get a custom chip with better injectors / turbo. The best I've seen is 115 bhp from the following company (they've done a lot of mods to achieve this so I don't think you'll get much more with just a chip): http://www.bb-automobiltechnik.de/bb..._9n_14_tdi.php |
| Almost sure, the Cupra intake won't fit as it's a different airbox. ![]()
__________________ Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille. Also driving around in a Mini ONE that thinks it's a Cooper! John Cooper Works airbox, Superchips Bluefin remap, Sprint Booster, 17" Cooper S Spokes |
Members Car: Audi S3 Thanks: 195
| This guy claims to be the only 1.4 Digital box on the market. http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1 Have you spoken to Jabba about buying through a Briskoda Group Buy? Perhaps a PM to Adrian (SkodiRS) would shed some light. A plug in will only increase fueling, although this is effective and produces good results it's no substitue for a set up on the rollers where the mapper can change other parameters such as boost pressure. A custom map can also be tailored to suit your needs, if you want all the torque in a lump or spread over the rev range for instance.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| | #9 | |
| Quote:
| | #10 | |
| Quote:
OOOOOOOOOOOOOOOOOOOOO.........claws out!!! What's the engine code of the 1.4 TDI then?
__________________ Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille. Also driving around in a Mini ONE that thinks it's a Cooper! John Cooper Works airbox, Superchips Bluefin remap, Sprint Booster, 17" Cooper S Spokes | |
| | #11 | |
| Quote:
| | #12 | |
| Quote:
| | #13 |
| My mistake, I was looking at the Arosa airbox on ETKA. Like I said I was ALMOST sure. ![]()
| | #14 | |
| Quote:
| | #15 |
| Briskodian | so could I fit this: http://www.bb-automobiltechnik.de/b...o_9n_14_tdi.php and still keep my tuning #resistor' mod box? Thanks |
| | #16 |
| Generally it's not a good idea to run resistor mod/tuning box with a chip.. I suggest you check for example www.tdiclub.com for some basic TDI tuning principle first, then come back with more questions http://tdiclub.com/TDIFAQ/TDiFAQ-6.html There you can also find instructions for making a bleed if you like, better check the instructions apply for the 1.4 tdi engine also, I haven't yet looked into this.. Last edited by jtstatic; 13-08-2005 at 15:59. |
| | #17 |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| Would anyone be deeply upset if I said that ETOS is telling me the AMF (1.4 diesel) uses the same intake connection parts as the ASZ/ATD engines? (pd130/pd100)
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! |
| | #18 |
| Uses the same driveshafts also _IF_ I remember correctly.. clutch/transmission is different though.. The 1.4 shares more parts with the 1.9 engine than you'd first think. You can get PD100 like performance easily so it's a good budget solution if you're not hoping much more power than that.. |
| | #19 |
| Briskodian | Tunning boxes only "Bend" signals from the sensors to the ECU, they are not a patch on a proper re-map. Custom Code (Phase 1) gives 105-110bhp and 175-180 ft-lb of torque ![]()
__________________ The Derv Doctor LTD |
| | #20 | |
| Quote:
![]() Last edited by jtstatic; 16-08-2005 at 05:52. | |
| | #21 | |
| Quote:
When I sold the car, I also sold the tuning box separately and got £20 for it, which brought down the cost of ownership even further ![]() Chris
__________________ Holding up the traffic in a little Italian.......... Last edited by ScoobyChris; 16-08-2005 at 08:29. | |
| Introduction to the Fabia | ColinD | Fabia I | 17 | 17-12-2007 14:11 |
| 330d - to chip or not to chip? that is the question...... | Huck | Off Topic and Chit Chat | 22 | 02-08-2005 00:58 |
| Fabia comparison. 1.4 16v vs. 1.9 TDi | Tom_vRS | Fabia I | 28 | 12-06-2005 18:56 |
| Powerbox on 1.4 TDi | Smiorgian | Maintenance & Performance | 12 | 07-02-2005 14:40 |
| Chip/ Remap 'V' Tuning Modules - TDI | cmcm789 | Maintenance & Performance | 1 | 25-10-2004 11:43 |
