This is a discussion on 100w bulbs only good for 5 hours... within the Fabia I forums, part of the Skoda Model Discussion Area category; Apparently the Philips rallye 100w bulbs are only good for about 5 hours constant use, and then they start to ...
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| Apparently the Philips rallye 100w bulbs are only good for about 5 hours constant use, and then they start to deteriorate, and in the end are actually worse than normal 55w bulbs. Might explain why my 3 or 4 year rallye bulbs aren't quite as bright as before. Anyone know if anywhere does 130w H3 mains, or maybe another type of 100w bulb that lasts a lot longer?
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! |
Members Car: Fiat Panda Thanks: 16
| Re: 100w bulbs only good for 5 hours... Is that 5 hours of constant use or 5 hours total use? I've run mine for a couple of hours a few times and they're still as good as ever Can't imagine where you'd want to do a 5 hour drive using them!!!Chris
| Broken :( Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 473
| Re: 100w bulbs only good for 5 hours... Jase, can't see that being a problem, as that surely points to constant use and the heat build up that this entails? Don't really know what's the longest I've ever used full beam for, not really thought about it before TBH! But don't come across as this prophet of doom as my set have just arrived for the Ibiza ![]() Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
| Re: 100w bulbs only good for 5 hours... I meant in terms of a "lifespan" - 5 hours. Seems pretty pathetic for them to start losing their power after this amount of time. I'm still happy enough with mine, but in no way are they as good as when I first got them, and that was second hand a few years ago after Jon had got good use from them too I reckon. ![]() Would like some 130w ones next - Pretty sure the wiring is good enough to provide reliable connectivity for that kind of power demand.
| | #5 | |
| Briskodian Join Date: Aug 2004 Location: Stirling
Members Car: Black Octavia vRS Thanks: 24
| Re: 100w bulbs only good for 5 hours... Quote:
__________________ Alan "Darth" - Black Magic Octavia VRS with Forge DV, BMC CDA induction kit, Milltek cat, Supersprint exhaust, Xenons, ESP, cruise, parking sensors and Kumho 225/45/17 tyres Been to Star sufficient bhp All time low - 7.8 mpg ![]() | |
| Briskodian Join Date: Aug 2005 Location: East UK
Members Car: Mini Cooper D Thanks: 19
| Re: 100w bulbs only good for 5 hours... Hi Jason All bulbs will lose brightness with age. Main beams suffer more as they seldom get hot enough to complete the "halogen cycle". If you pull the bulbs and have a look, you will often see a dark residue on the inside of the glass. You may be able to remove this by running main beam for a half hour to cook the residue off and re-deposit it. Personally, I would just change them if the glass has gone dark. Bulbs often need freshening up by replacing. I fitted Osram Siverstars around 42,000 miles ago and they have just both popped within a couple of weeks of each other. Good to note that neither bulb had gone dark inside. I only had the local shop to replace in an emergency Saturday evening. They supplied an Elta bulb which as far as I can tell produces similar light to the Silverstar. Not bad at £4.99. I am spending rather too much on lighting this month as I am waiting for the dual Xenon setup to arrive for the MR2. Chris
__________________ Red Fabia vRS. Gone but not forgotten .Chilli Red / white Mini Cooper Diesel with dual controls. Silver 53 MR2. Mods: PPE 4>1 manifold | PPE Mangnaflow high flow cat | Blueflame catback exhaust | Pikey inlet mod | 3.0 Racing Chassis stiffening brace kit | BC Racing fully adjustable coilovers | TF loud. Details here My MR2 Page Last edited by Chris GB; 14-11-2006 at 01:48. |
| | #7 | |
Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae | |
| Briskodian | Re: 100w bulbs only good for 5 hours... Are you sure the standard wiring can cope with that much current? I'd be careful if I were you - you don't want to end up melting the wiring or causing a fire. |
| | #9 | |
Mine have covered a shade under 30k miles in a year and a bit and are still as bright as ever The Fabia ones were also in for a year and a bit and covered a similar mileage and as far as I know are still going strong ![]() One thing to watch out for with the 130W bulbs (aside from the wiring and lens issues!) is that there will be a big difference when switching between dipped and main beam. This won't be a problem when switching main beam on, but you'll be plunged into relative darkness when switching it off! Chris
__________________ Holding up the traffic in a little Italian.......... Last edited by ScoobyChris; 14-11-2006 at 19:53. | |
| | #10 |
| Re: 100w bulbs only good for 5 hours... Might just get a replacement set of 100w bulbs then. £25 odd seems a lot of dosh for 5 hours premium performance though.
| | #11 |
| Re: 100w bulbs only good for 5 hours... £21.51 from Powerbulbs with 10% discount Jase ![]() So it could be worse ![]() You'll have to keep a stopwatch in the car, and report back on bulb performance... Steve
| | #12 |
| Briskodian | Re: 100w bulbs only good for 5 hours... I had 130/90 h4 bulbs in an Astra Gte a few years ago but the wiring was getting hot even after just a few miles so I took them off and stuck with 100/80 which were fine. Last edited by The The; 14-11-2006 at 20:07. |
| | #13 |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 48
| Re: 100w bulbs only good for 5 hours... Considering the LPG stuff you've got you'd really want to avoid a fire (IMHO of course )
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| | #14 |
| Re: 100w bulbs only good for 5 hours... Just ordered some new ones with a 10% code courtesy of google. There was a code on Briskoda too, but it had expired.
| | #15 |
| Briskodian | Re: 100w bulbs only good for 5 hours... Can't see how they are going to deteriorate significantly? |
| | #16 |
| RICHARD Join Date: Apr 2005 Location: Twickenham - Middlesex
Members Car: Skoda Fabia >> VW Golf >> Seat Ibiza >> VW Polo Thanks: 11
| Re: 100w bulbs only good for 5 hours... Fitted 100W to mine @ same time as fitting the xenons.... 100w really does seem dim and as a result have never ever used them!!
__________________ First Car: Skoda Fabia MK1 1.2 12v Comfort Replaced with: Volkswagen Golf MK4 GT 1.9TDI Replaced with: Seat Ibiza MK4 Sport 1.9TDI Replaced with: Volkswagen Polo MK6 Ltd. Edition Sport 1.4 16v |
| | #17 |
| Re: 100w bulbs only good for 5 hours... See post above. The buld filament evaporates and deposits itself on the bulb glass, reducing light output. Main beams suffer more as they seldom get up to full working temperature, where a halogen bulb "cleans" itself via the halogen cycle. See this link: How does the Halogen Cycle work? HTH Chris
__________________ Red Fabia vRS. Gone but not forgotten .Chilli Red / white Mini Cooper Diesel with dual controls. Silver 53 MR2. Mods: PPE 4>1 manifold | PPE Mangnaflow high flow cat | Blueflame catback exhaust | Pikey inlet mod | 3.0 Racing Chassis stiffening brace kit | BC Racing fully adjustable coilovers | TF loud. Details here My MR2 Page |
| | #18 |
| Briskodian Join Date: Feb 2006 Location: Essex
Members Car: Silver Fabia vRS with cruise and 5 disk CD changer as the 6th slot has stopped working. Thanks: 21
| Re: 100w bulbs only good for 5 hours... I bought Halfords own rally bulbs. They told me that I was not to use them on the road, then very kindly offered to fit them I have used mine for more than 5 hours (in total rather than constantly) and mine are easily as bright.
__________________ |
| | #19 | |
Chris
__________________ Red Fabia vRS. Gone but not forgotten .Chilli Red / white Mini Cooper Diesel with dual controls. Silver 53 MR2. Mods: PPE 4>1 manifold | PPE Mangnaflow high flow cat | Blueflame catback exhaust | Pikey inlet mod | 3.0 Racing Chassis stiffening brace kit | BC Racing fully adjustable coilovers | TF loud. Details here My MR2 Page | |
| | #20 |
| Nuts Join Date: Nov 2006 Location: Greater Manchester
Members Car: Fabia vRS Thanks: 151
| Re: 100w bulbs only good for 5 hours... Some information on bulbs here :- Bulb test: H4 blue | Product Tests | Car Reviews | Auto Express AutoExpress tests on H4 bulbs |
| | #21 |
| Re: 100w bulbs only good for 5 hours... While we are on the subject of bulbs, anyone had any experience of HIR bulbs as developed by GE ans currently made by Toshiba? The bulbs use a thicker filament, but heat it by reflecting IR back to the filament to achieve a large hot filament. Chris
| | #22 |
| Briskodian | Re: 100w bulbs only good for 5 hours... Sounds a bit risky fitting these 100w bulbs the increase in current means a big increase in heat in the wiring I would have thought may even possibly cause a fire and then it would be bye bye furby. |
| | #23 |
Members Car: 4x4 turbo estate Thanks: 18
| Re: 100w bulbs only good for 5 hours... i've had 100W bulbs in my octavia for nearly 2 years now without any issues at all ![]()
| | #24 | |
![]() Chris
| | #25 |
| Briskodian | Re: 100w bulbs only good for 5 hours... Ive got some from a friend in HK 110W's and they've lasted so far without any differences (4000 miles). This is £15 for 3 sets (501, H3's and H7's). So im quite suprised that philips ones die so quick.. -John |
