40,620 Members 1,518,590 Posts
12V Dash Supply
This is a discussion on 12V Dash Supply within the Fabia I forums, part of the Skoda Model Discussion Area category; Anybody tell me the easiest way to get a pre/post-ignition 12v power supply to near the fascia air vents where ...
Old 25-03-2005, 16:59   #1
Tango49's Avatar
Members Car:
12V Dash Supply
Anybody tell me the easiest way to get a pre/post-ignition 12v power supply to near the fascia air vents where I am mounting a ProClip swivel mount for my imminent Dell Axim X50v PocketPC?
I've no problem tackling technical/tricky projects - just didn't want to learn the hard way if someone else has already done it.
Thanks a bunch
Tango49 is offline
Old 25-03-2005, 17:15   #2
Partner
Lummox's Avatar
Images: 2
Best bet is to tap into the ISO connector on the back of the stereo, iirc pin 7 in the black conector is perm live, pin 4 is the ignition one (goes off when keys taken out). But a test light will clarify this.
These are often the two that need swapping when fitting some aftermarket headunits.
www.unit18.co.uk
Lummox is offline
Old 25-03-2005, 18:03   #3
The The's Avatar
Members Car:
There are 2 connectors at the back of the stereo, one is for power and one is for the speakers. The connector with all the power in it is BLACK
As for the wires:
+12v is BROWN and RED
Earth is BROWN
This is the advice i was given and it worked perfectly, this is a live feed when the key is in only. the ignition does not need to be on.
The The is offline
Old 25-03-2005, 18:13   #4
Tango49's Avatar
Members Car:
Thanks Lummox & TheThe,
Seems just the job - I'll be to it straight away!
Cheers
Tango49 is offline
Old 25-03-2005, 18:26   #5
vRSK99's Avatar
Members Car: Fabia vRS
What sort of powered mount are you using?I use a brodit pro clip for my x50v, but it's not powered.Brodit told me they were'nt planning a powered one.The only one Ive seen so far is a Seido one with a bulky speaker on it!Would be interested to know where you got it?
:orb_cool
vRSK99 is offline
Old 25-03-2005, 20:20   #6
Tango49's Avatar
Members Car:
I tried Gomadic first. That was powered but needed the interface cable to be plugged in as the unit was slid into the cradle - bit messy. And it had no speaker, which I wanted. So I ordered the Seidio one from GlobalPositioningSystems.co.uk (or was it .com?) and am still waiting for it to arrive. (I have read some naff comments about ordering it direct from Seidio so went for a UK seller). Good thing seems to me is that its dark grey and less conspicuous than Gomadic's bright silver finish and the cradle has the male plug already fitted. And I like the look of the swivel mount too.
I bought a Brodit clip along the way as well, but snapped-off the bottom lug while stretching it open across the air-vent/fascia - duh!
What sofware are you running?
Tango49 is offline
Old 25-03-2005, 21:09   #7
vRSK99's Avatar
Bought the unit primarily for navigation, using tom tom 3 with a combined 256k memory/gps reciever card.The set up works great and i use it most days for my work.Bought the european maps a few weeks ago for a business trip to denmark and it was spot on.Speed camera software works well too.Also use it as an mp3 player and for general business use.Excellent bit of kit.VGA full screen emulator is worth a look.
:orb_cool
vRSK99 is offline
Old 25-03-2005, 23:32   #8
Tango49's Avatar
Members Car:
I also bought TomTom 3 for the road plus 1Gb SD card (still waiting for the X50v - 9 days to go apparently). Bought mine for aviation navigation backup use with a view to getting used to its functionality in the car. Will also load navGps and PocketFMS when the thing arrives. Can't wait.
Scuse my ignorance but what's VGA full screen emulator about and where do you source it from? And can you get TomTom working in landscape mode?
Tango49 is offline
Old 26-03-2005, 12:30   #9
Tango49's Avatar
Members Car:
You might want to look at this for more info on the Seidio mount:
http://reviews.schrags.com/index.php...d=66&Itemid=43
Tango49 is offline
Old 26-03-2005, 19:23   #10
vRSK99's Avatar
Just ordered the seidieo mount!!. Looks slimmer than i was led to believe! Thanks for the link.The vga emulator makes your PDA screen identical to a pc one.For example,full desk top or full pages instead of having to scroll down and accross trying to view downloaded pages off 'tinternet.You have to be accurate with the stylus but everything is perfectly readable because of the vga dell screen.Got it off a customer.Willing to try e-mailing it if you like.
vRSK99 is offline
Old 28-03-2005, 14:36   #11
Tango49's Avatar
Members Car:
Yes please, I'd appreciate that.
See your PM's - I've sent my email address to you.
Thanks for your help.
Tango49 is offline
Similar Threads
Fitting an 7" LCD to a Fabia Dash? uhf Fabia I 1 14-12-2004 08:43
Adding a switch to Fabia dash bryand Maintenance & Performance 14 11-09-2004 10:18
Old AT Power Supply ccrosb The Tech Shed 9 20-04-2004 18:16
Octavia Rear 12v Socket question Mickos Maintenance & Performance 10 28-01-2004 00:15
My computer power supply went bang mannyo Off Topic and Chit Chat 14 28-02-2003 15:09
