40,620 Members 1,518,564 Posts
17" alloys for a fabia
This is a discussion on 17" alloys for a fabia within the Fabia I forums, part of the Skoda Model Discussion Area category; Deleted...
Old 11-07-2007, 12:01   #1
Briskoda Staff
auroan's Avatar
Deleted
The Audi Fleet;
'05 Audi A4 2.0 Tdi SE - interior light pack, 3 spoke mfsw, 30mm drop, front seat nets (back), fiscon BT handsfree.
'96 Audi A4 2.6 Avant (Breaking - Check out http://shop.ebay.co.uk/merchant/auroan)
'93 Audi 80 Avant - Charlie the labrador transporter.
auroan is offline
Old 11-07-2007, 12:20   #2
robmawer's Avatar
Members Car: Octavia 1.6 Ambiente
Re: 17" alloys for a fabia
What's the PCD of them? Are they Audi wheels by any chance? In which case they're likely to be 5x112 rather than the 5x100 the Fabia uses...?
Rob.
robmawer is offline
Old 11-07-2007, 13:32   #3
Briskoda Staff
auroan's Avatar
Deleted
The Audi Fleet;
auroan is offline
Old 11-07-2007, 13:34   #4
Members Car:
7.50 - This is the width of the rim
17 - Is the size of the wheel
ET32 - The offset
225 width tyres wont fit on the fabia and will rub, 205 or 215 are needed.
Hope thats correct
Shaun
Shaun L is offline
Old 11-07-2007, 13:36   #5
Briskoda Staff
auroan's Avatar
Deleted
The Audi Fleet;
auroan is offline
Old 11-07-2007, 14:11   #6
Broken :(
Wardy's Avatar
Members Car: Skoda Fabia vRS
Yep - those alloys will be fine on the Fab, as long as you fit 205/40/17 or 215/40/17 tyres.
Steve
Wardy's Fabia vRS
xenons : sunroof : cruise : OEM+
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is offline
Old 11-07-2007, 18:02   #7
Philip26's Avatar
Members Car: Fabia VRS
I keep toying with the idea of putting 225/35x17s (Michelin Sports £92 each fitted) on 7.5s i.e. virtually the same rolling circumference. These should fit fine but would they need offsetting front/read for clearance on full lock? I think I have read of only one person running them...
Philip
Nurburgring Tourist 2006
Oulton Park Trackdays: 03/11/06, 26/06/07, 02/11/07
VRS now Jabba'd - Stutter & (Nearly) Smoke free
Philip26 is offline
Old 11-07-2007, 21:36   #8
Broken :(
Wardy's Avatar
Don't know why you'd bother to be perfectly honest? 215s are perfectly fine, and also run a slightly kinder profile. A 35 will be mighty firm!
Steve
Wardy's Fabia vRS
Wardy is offline
Old 11-07-2007, 21:38   #9
Partner
Lummox's Avatar
Images: 2
Originally Posted by Shaun L View Post
45mm profiles will mostly likely rub and offset the speedo a lot, you need 40mm (Up in rim size, down in tyre profile).
Tyre profile isnt in mm, its a percentage of the width.
www.unit18.co.uk
Lummox is offline
The Following 2 Users Say Thank You to Lummox For This Useful Post:
Babs (12-07-2007), Shaun L (12-07-2007)
Old 12-07-2007, 05:54   #10
Fabia156's Avatar
Members Car:
Tried that size on my car for a whole year (225/35 17) awsome performance but Aweful comfort..use to rub a little bit when doing U turns... changed to 205/40 17.. verrry slight drop in handling.. but a lot more comfort...
If you wanna go really extreme there're tyres of size 215/35 17.. Falken fk452 make that size and they're great tyres..
225/45 might not fit in the rear though and if it fits it'll rub a lot and the car will have to sit on a higher suspension.. otherwise will rub a lot...
1.4 16V
Fabia156 is offline
Old 12-07-2007, 13:37   #11
Philip26's Avatar
Fabia156 when you were running the 225/35x17 was it on standard shockers/springs or uprated shockers/lowers or a combination of the two?
I was hoping to use lowered springs with standard shockers i.e. Standard shockers are approx. 20% softer so putting the 225s on should firm the suspension up without the expense of uprating the shockers - hopefully not compromising the ride.
I was bothering because I will need as much traction as I can get if I get my vRS remapped to 300lb/ft torque!
Philip
Philip26 is offline
Old 12-07-2007, 19:10   #12
Members Car:
Cheers for correcting me
Shaun L is offline
Old 12-07-2007, 19:34   #13
Partner
Lummox's Avatar
Images: 2
No worries, everybody learns something then.
www.unit18.co.uk
Lummox is offline
Old 13-07-2007, 00:15   #14
Fabia156's Avatar
Members Car:
My car has h&R springs with standard shocks..If you reallly need that extra bit for traction then go for these tires.. but like i said you will have to give up on some comfort especially if you use low springs.. but traction is and Handling is very good as these tires are very low profile
1.4 16V
Fabia156 is offline
The Following User Says Thank You to Fabia156 For This Useful Post:
Philip26 (13-07-2007)
