This is a discussion on 17559 Engine code 1.4 16v within the Fabia I forums, part of the Skoda Model Discussion Area category; Recently had my fabia 1.4 16v serviced at the skoda garage. After approx 100 miles the engine warning light came ...
| Briskodian | 17559 Engine code 1.4 16v Recently had my fabia 1.4 16v serviced at the skoda garage. After approx 100 miles the engine warning light came on I had the code read: 17559 Long Term Fuel Trim Additive Air ; Bank 1 ; Range 1 : System too Lean the car also had too much oil in it. Took it back had it drained and they said it was the oil and they reset the code. Now after another 100ish miles the light is back on with the same code. Has anyone else had this code before? Or any idea what could be the possible causes of it? |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: 17559 Engine code 1.4 16v Pop the engine cover/air box off and have a look in the throttle body, see if there is any oil in it. I doubt that will be the fault, does sound like a faulty lambda probe I would think. How does it run normally? Smooth or a bit lumpy? |
| Briskodian | Re: 17559 Engine code 1.4 16v Yes theres a film of oil in there. They've said it needs new piston rings and this is a common fault and nothing to do with the fact they overfilled it with oil. Oil vapour coming up past the piston rings? 27000 miles. |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 67
| Re: 17559 Engine code 1.4 16v Not good. What year is your car and is it still under warranty, and how far was the oil above the top range on the dipstick?
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.12mpg... |
| Briskodian | Re: 17559 Engine code 1.4 16v Hi, It's a 2002 plate. Not under skoda warranty. The garage has said Skoda uk will pay half the labour or something. This has been a very bad experience, I have no way to prove they have broken it. They insist that the oil overfill could not do it. I don't know enough about engines to know. I say to them you've broken it, they say no. |
| Re: 17559 Engine code 1.4 16v Piston rings are common sadly. Its not oil vapur coming up, its compression gasses going down, this creates to much crankcase pressure and oil/vapour is blown up the crankcase breather and into the air filter. |
| Briskodian | Re: 17559 Engine code 1.4 16v i'd say about 7mm+ above the top. They billed me for 4.1 litre and it takes 3.2 litre. Last edited by isinglass; 24-07-2006 at 18:30. |
Members Car: '97R BMW 328i Saloon Thanks: 728
| Re: 17559 Engine code 1.4 16v Piston rings is a common problem on the 1.4 unfortunately - hence Skoda UKs offer of half the labour. I think the problem may have been accelerated by the oil overfill - but it would have reared its ugly head eventually...
| Briskodian Join Date: Dec 2002 Location: Norwich
Members Car: Fabia VRS and Elegance Thanks: 0
| Re: 17559 Engine code 1.4 16v Just curious, how does the engine cover come off the 1.4 16v....? Fiddling with mine...I can't get it off. Pete.
__________________ 2005 Fabia VRS - Lemon Yellow - JabbaSport Custom Remap, JabbaSport ARB, Sachs Uprated Organic Clutch, Eibach Pro Dampers and Lowering Springs, PD160 Air Intake and Green Stuff Filter, Forge FMIC, Front Strut Brace, 312mm brakes, Renault Aero Wipers, Cupholder. 2004 Fabia 1.4 16v Elegance - grey - standard, except for the addition of a cup holder and some mudflaps...oh, and some 15 inch alloys. |
| | #10 |
| Re: 17559 Engine code 1.4 16v Pull it up. |
| | #11 |
| Re: 17559 Engine code 1.4 16v It doesn't budge. On my fabia vrs, comes off very easily....on the 1.4 16v...it's fixed solid.
| | #12 |
| Re: 17559 Engine code 1.4 16v Eat some shredded wheat and give it another go. |
