This is a discussion on 2 new tyres for Fabia VRS within the Fabia I forums, part of the Skoda Model Discussion Area category; Got my 10,000 service today and dealer confirmed that there was a problem with my front offside tyre, it has ...
| Briskodian | 2 new tyres for Fabia VRS Got my 10,000 service today and dealer confirmed that there was a problem with my front offside tyre, it has a small puncture on the wall which can't be repaired. Also 3mm tread left so a good idea to get two new tyres. The dealer says the factory Continentals are good and wants £100 each so is there any savings in getting an independent tyre shop to fit them? Any suggestions about other makes? |
Members Car: Fiat Panda Thanks: 16
| Re: 2 new tyres for Fabia VRS Imho, ditch the factory Conti's and get some Toyo T1-Rs or Falken FK452's (if they're available in your size). Cost is £60-£70 a corner fitted and they are significantly grippier.... Chris
| Briskodian | Re: 2 new tyres for Fabia VRS £100 each, what a rip off. Go to an independant garage and fit some premium tires, be it goodyear / toyo / falken, just get decent ones ![]()
__________________ ![]() Star Remap, BMC, Helix, 312's, Magnex, Vibratechniks mount, Allard Power Pipe, VMaxx Coilies, CCV mod, Pikey Short Shifter, Stainless Boost pipes, Pikey arch mod, HID's, 17's, Heated Seats, Cruise + many more![]() |
| Briskodian Join Date: Jan 2007 Location: South Wales
Members Car: Fabia vRS Diamond Silver Thanks: 1
| Re: 2 new tyres for Fabia VRS I just bought a pair of Stunners. So far so good and an immdediate improvement as far as noise goes compared to my old Hankook Ventus.
__________________ Mods to date - Angel Remap, Green Cotton filter, Jabba ARB, 9mm EGR Gasket |
| Briskodian | Re: 2 new tyres for Fabia VRS im picking my vrs up on friday and the dealer just fitted stunners wotever they are. I wasnt tooo amused because i wanted goodyears or yoko's but what can you do. How are they do they grip/handle well? |
| | #6 | |
| Moderator | Re: 2 new tyres for Fabia VRS Quote:
If changing fabia vRS tyres I would consider 215/40's instead of the 205's They tend to be cheaper and give the car a bit more grip.
__________________ ![]() | |
| | #7 | |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! | |
| | #8 | |
| Briskodian | Re: 2 new tyres for Fabia VRS Quote:
| Moderator | Re: 2 new tyres for Fabia VRS I wouldnt say they are dangerous, Just as long as you know what you have got and dont expect them to stick like the proverbial to a blanket then you'll be fine. If your driving style is 'normal' and not hooning about then they will probably be more than adequate
| | #10 |
| Briskodian | Re: 2 new tyres for Fabia VRS Tis a strange one how skoda recommends certain branded tires but when they sell them they stick on the cheapest ones possible. I bought a car over the phone from a Skoda dealer, said yes we will put new front tires on etc, good quality ones Turned up and they were Kleber ones - NOT IMPRESSED!! W4nkers
| | #11 |
| Briskodian Join Date: Jan 2008 Location: Dublin, Ireland
Members Car: Fabia Vrs Thanks: 31
| Re: 2 new tyres for Fabia VRS I've just replaced a punctured tire myself, and I'm just replacing like with like... Bridgestone Turanzas. What do you lot think of those? But Scotsmac, I do think if I were replacing both though, I'd go for Goodyears/Toyos from all the praise they get on here. Happy shopping! |
| | #14 |
| Briskodian | Re: 2 new tyres for Fabia VRS Thanks for all the suggestions! Staying 30 miles from Glasgow I need new tyres fitted locally. It seems difficult finding Toyo or Falken dealers on the net so is Kwikfit any good for these tyres? One other question is what is the difference between the 205/45R tyres on the car and 215/40 suggested by a forum member? |
| | #15 |
| Briskodian | Re: 2 new tyres for Fabia VRS Stay away from Kwiksh1t. 205/45 (standard) Your saying 215/40 215 is the width of the tire, so you will be going +10mm width 40 is the sidewall, so a 40 sidewall is shorter than the 45, should reduce bodyroll a wee bit
| | #16 |
| Briskodian | Re: 2 new tyres for Fabia VRS Hi, Have you tried here I've used them in the past to buy contiSportContact2's, had them delivered to my house before taking them to a small local garage to have them fitted. They also offer you the choice of having them delivered directly to a garage local to you ready for fitting, I guess you'd have to clear this with the garage first though. Mike. |
| | #17 |
| Briskodian | Re: 2 new tyres for Fabia VRS I've been running on the Bridgestone Turanzas originally fitted and have been pretty satisfied overall. Grip is good in wet and dry, no nasty surprises when pushing hard and they wear well (~15k out of the fronts) Would have them again, but would also consider some of the other popular suggestions featuring regularly in these threads, eg Toyo Proxes. |
| | #18 | |
| Ho Ho Ho Join Date: Feb 2007 Location: Ashford, Kent
Members Car: Silver Fabia vRS Thanks: 104
Would have these again. Ben
__________________ Ben | |
| | #19 |
| Briskodian Join Date: Jul 2006 Location: milton keynes
| Re: 2 new tyres for Fabia VRS I've been running on the Bridgestone Turanzas originally fitted and have been pretty satisfied overall. Grip is good in wet and dry, no nasty surprises when pushing hard and they wear well (~15k out of the fronts) Would have them again, but would also consider some of the other popular suggestions featuring regularly in these threads, eg Toyo Proxes. I had these originally, then i cjanged to Goodyear F! and the difference was amazing,both in the and dry a massive improvement and gives much more confidence Matt
__________________ Black Fabia Vrs, PD160 air intake, Pipercross filter, Aero Wipers, Phillips 80% extra bulbs |
| | #20 |
| Broken :( Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 473
| Re: 2 new tyres for Fabia VRS Just got some Toyo Proxes 4s yesterday. I'll report back once I'm running them. Currently on Turanzas and I've been happy with them. Noisier than P-Zero Neros or the T1-Rs though, both of which I've run on this current car. Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
| | #21 | |
| Briskodian Join Date: May 2007 Location: Staffordshire
Members Car: Fabia vRS Thanks: 99
Only problem was that the tyre fitter said they were very tight to get on. So tight that he damaged two of the alloys. Not impressed ![]()
__________________ Dieselist and proud. | |
| | #22 | |
| | #23 |
Members Car: Black Magic Fabia vRS Thanks: 388
| Re: 2 new tyres for Fabia VRS Just switched from Proxeses to P Zero Neros, and am glad that I no longer have the slight 'ringing' noise at motorway speeds, although they seem a bit twitchy in fast bends (could be that there's still some mould release compound left on the tread, though) Made the change 'cos they were getting near the wear markers front and back, and I would probably have stayed with the Toyos if I didn't think that leaving big >>>>>>>>>>>>>>>> tread marks on the drive didn't quite go with the baby seat in the back! ![]()
__________________ |
| | #24 | |
Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae | |
| | #25 |
| Briskodian Join Date: Jan 2005 Location: Durkar
Members Car: Octavia 130pd Elegance Estate Images: 10 Thanks: 124
| Re: 2 new tyres for Fabia VRS have had 2 kumho ecsta's fitted 205/45/16 (Standard Size). They've been on for just over 1 month and they are loads better that the Conti Sport Contact 2's that were on as standard. Only got 14k out of the contis so hoping for more out of the Kumhos. Road noise is no different however dry and wet grip has increased with the Kumhos |
