Calipers & pads for 312mm Fabia VRS upgrade - PLEASE HELP!
This is a discussion on Calipers & pads for 312mm Fabia VRS upgrade - PLEASE HELP! within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi all, I bought some grooved 312mm discs for my Furby vrs with some red stuff pads AGES ago, however ...
Old 28-04-2008, 12:21   #1
cib_cobra's Avatar
Default Calipers & pads for 312mm Fabia VRS upgrade - PLEASE HELP!
Hi all,
I bought some grooved 312mm discs for my Furby vrs with some red stuff pads AGES ago, however i was told the pads would wear the discs quickly so sent them back.
The problem i've got is that that company i bought the discs & pads from said i could do the conversion without changing the calipers - when i questioned him he said he'd done numerous conversions using the standard Furby VRS calipers?!
So anyways the problem i got is that i can't find any calipers or pads unless i pay north of £100-£200 (Cheapest calipers are reconditioned ones @ £67 each + VAT)!!!!!
I was hoping for a decent 2nd set off a car that has 312mm discs as standard - any ideas on cars & where i can get some from?
Have been looking for a written off TT i can nick 'em off, but can't find one anywhere!
I need to get them quick as my current pads are nearly on the metal!
Cheers in advance for any help.
Chris
Fabia VRS.
Leon Cupra R Front Splitter, 160+ air box & intake. K&N panel filter. Remap to 198BHP, 334lbs/ft. Eibach Springs. 312mm grooved discs. Rear ARB. Window tints. ICE
cib_cobra is offline
Old 28-04-2008, 12:24   #2
ultra_joel88's Avatar
Default Re: Calipers & pads for 312mm Fabia VRS upgrade - PLEASE HELP!
you need new calipers and carriers
I got some off ebay for £150 including postage
'04 Fabia VRS - 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Boost + Volt Gauge, Window Tints
ultra_joel88 is offline
Old 28-04-2008, 12:35   #3
cib_cobra's Avatar
I've got the carriers ready and already painted VRS green, so it's just the calipers and pads required.
Have heard octy vrs ones will fit but not sure whether MK1 or MK2?
Fabia VRS.
Old 28-04-2008, 15:16   #4
Howdy,
To do the conversion you'll need to replace both the carriers and calipers with the set off an Audi TT... The offset of the carriers for the TT caliper is different to that of the OEM Furby one...
I got a set of Audi TT calipers and carriers off of eBay for £155... awesome price for them and went on a treat! (painted with flat green Hammerite; tip: give them 3-4 coats of paint otherwise temp fatigue can flake the paint off)...
I got some 312mm Tar-Ox G88's and some Mintex Extreme pads to go with them... Experiencing many negative-G's now!!!!
Bomski
bomski is offline
Old 28-04-2008, 15:20   #5
mello in yello
postmanpat's Avatar
Golfturbo on here sells the full set, discs, pads, carriers and callipers. Drop him a pm and see if he can help you out
Originally Posted by Emily-Elizabeth
Sperm donership: It is not like giving blood, it is tossing away...............
Postmanpats car Fabia vRS Zennons, ESP, autochanger, 3rd headrest, heated seats, cruise control
SWMBO Octy Mk2 vS maxidot, duel zone wotsit, cruise, parking sensors, 18" alloys
postmanpat is offline
Old 28-04-2008, 15:30   #6
Why me ?
auroan's Avatar
Whats the furby vRS std disc size ?
If it's 288 then the calipers will fit. All you need is 312 discs and carriers. Then just get pads to fit std vRS setup.
I've done this upgrade on a Bora with 288 discs and it's defo just the carriers and discs.
'00 AUDI A4 2.8 Quattro - with a few mods
Audi A4 2.6 Avant (Breaking - Check out http://shop.ebay.co.uk/merchant/auroan)
auroan is offline
Old 28-04-2008, 15:44   #7
cib_cobra's Avatar
See that's what the chap that sold me the discs, carriers & pads said, but i always thought you'd get more braking power with the bigger calipers?!
Also golf turbo only does full kits.
GSF Car Parts, cheap car parts direct to you have got some pads off a TT for £35 + vat
eBay UK Shop - DUBSHACK COVENTRY: MK3 GOLF, MK4 GOLF, ENGINE'S also do second hand kits
Fabia VRS.
Old 28-04-2008, 15:49   #8
Why me ?
auroan's Avatar
The calipers arn't bigger on the TT. The breaking force is greater due to the caliper gripping the disc further from the centre of the hub.
If the vRS discs are 288, I'll put £100 down that the calipers don't need replacing
auroan is offline
Old 28-04-2008, 15:59   #9
Moving Stables
skudmissile's Avatar
They do need replacing on the fabia VRS.
The fabia has a different caliper than the golf/bora/tt.
The calipers on the 288 golf brakes are the same as the 312mm tt ones but the fabia 288mm brakes are completely different.
For the fabia you need calipers, carriers, discs, pads and if you really want to be ok brake pipes
Bored of the volvo already
skudmissile is offline
Old 28-04-2008, 16:02   #10
Why me ?
auroan's Avatar
fair enough.... whats different ?
auroan is offline
Old 28-04-2008, 16:05   #11
Moving Stables
Physically
The caliper on the lucas fabia brakes is held in place with two 12mm bolts on the top and bottom guide pins.
The caliper on the gold version is held in place by 2 7mm allen guide pins and a sping clip on the outside.
They are just different braking systems but use the same disc
Random but true.
Old 28-04-2008, 16:16   #12
Why me ?
auroan's Avatar
So much for VAG keeping the number of different parts to a minimum. Take it this is the same on polos and ibizas then.
auroan is offline
Old 28-04-2008, 19:49   #13
Lofty86's Avatar
So auroan, how many people can claim this £100??
'53 Fabia vRS. PD160 intake, Green Cotton Filter, Pikey Intercooler Mod, 312mm Brakes. Debaged Rear End. Fixed The Rear Door Leak!
Ready to fit: 19Row Fuel Cooler, Braided Fuel Line, NACA Duct, Wheelarch Pikey Mod.
To Buy: FSD's, Pro1.2's, FMIC, LSD, Devils Own Water/Meth Injection, Clucth, SM Flywheel, Hybrid Turbo + Remap. ££££
Lofty86 is offline
Old 28-04-2008, 19:58   #14
U18 Automotive
Lummox's Avatar
Its actually all in my rather helpfull guide to fitting the brakes, shame no one ever reads it...lol
http://briskoda.net/forums/technical...ctorial/47673/
Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
Old 28-04-2008, 20:21   #15
Moving Stables
How do you think i found out about it
Thanks Ross for your super dooper guide
John
Old 29-04-2008, 08:56   #16
Why me ?
auroan's Avatar
LOL.... all bets are off.
auroan is offline
Old 29-04-2008, 13:09   #17
cib_cobra's Avatar
I take it this means i'll be ok using the ones off of a TT then?
Big thanks for all the input
Fabia VRS.
Old 29-04-2008, 13:21   #18
Why me ?
auroan's Avatar
yes TT, golf, Octy, bora . As I've just learned.
Major edit !!! yes I read the post wrong.... you do need the above
auroan is offline
Old 29-04-2008, 13:33   #19
Yes! You Need The Calipers From A Tt225
Old 29-04-2008, 13:38   #20
Moving Stables
nope, TT, golf, Octy, bora are a no go. As I've just learned.
Your confusing me now
If upgrading to 312mm and you have the correct caliper hangers for the TT golf then yes you will need the TT golf caliper too.
I think the confusion is coming from the fact that the fabia lucas calipers will not fit the 312mm golf tt hangers
So in answer to OP you will need the calipers from a golf/tt/bora/octy
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
