39,456 Members 1,489,938 Posts
Camber issue
This is a discussion on Camber issue within the Fabia I forums, part of the Skoda Model Discussion Area category; as i previously posted i hit a kerb and bent a few things... had the new parts fitted which were ...
Old 21-01-2008, 19:10   #1
KTP
eeeeeeeeevil.
KTP's Avatar
Members Car:
Camber issue
had the new parts fitted which were a new wishbone, balljoint and tracking arm.
the only problem is the camber is off now so its running on the edge of the tyre, nothing else looked bent and i'm not sure how i can check it all. i done a search on camber adjustment and seemingly this cant be done?
i'm a bit stuck for ideas.
KTP is offline
Old 21-01-2008, 20:52   #2
I parked up 1st
ric04vrs's Avatar
Members Car: silver Fabia VRS
Re: Camber issue
you need to get a full 4 way alignment check , to determine exactly what is bent
i suspect from looking at your pictures that the shock adsorber and/or knuckle are bent , it took quite a hit to fold the wishbone up that far
not so bored now
ric04vrs is offline
Old 21-01-2008, 21:48   #3
Moving Stables
skudmissile's Avatar
Members Car:
Re: Camber issue
or the subframe could have been pushed out of line?
Run out of CASH
skudmissile is offline
Old 21-01-2008, 22:34   #4
Members Car:
Re: Camber issue
A trip to Chathams, or to save some money Star Performance seem to be your two alternatives - plenty scope for adjustment - but that final statement only applies if nothing else is bent. If you park on the level and view the car from the front - wheels straight ahead, you should be able to see if one side has too much -ve camber and the other none or slightly +ve camber - this will not sort anything but at least you will see what the problem is. Also check the toe - should look parallel or slightly toe out - but in any case as ric04vrs said "you need a full four wheel alignment done".
rum4mo is offline
Old 22-01-2008, 21:24   #5
stevenh's Avatar
Members Car: Octavia vRS
Re: Camber issue
CLCM in Sighthill Ind Estate without a doubt mate
stevenh is offline
Similar Threads
Camber kits? gmaster Maintenance & Performance 9 06-01-2008 09:56
Camber Kits. Can you get them? faboka vrs Maintenance & Performance 6 20-04-2007 15:26
camber angle jaguar_uk Fabia I 4 05-11-2006 03:11
Excess negative camber? sjfw Fabia I 0 10-10-2006 16:00
Can you adjust the camber and toe-in on the RS? TurboČ Maintenance & Performance 8 22-07-2003 06:17
