This is a discussion on Clue to crazy alarm? within the Fabia I forums, part of the Skoda Model Discussion Area category; Some of you may recall a thread I posted a while back re my crazy alarm. It can work fine ...
| Briskodian Join Date: Jun 2005 Location: Northants
| Some of you may recall a thread I posted a while back re my crazy alarm. It can work fine for weeks and then out of the blue start playing up something terrible - triggering at will, refusing to switch off...... ![]() Anyway, I had a quick play with vag-com yesterday and read the following fault: Control Module Part Number: 6Q1 937 049 Component and/or Version: BORDNETZ-SG. 1S30 Software Coding: 09394 Work Shop Code: WSC 13765 1 Fault Found: 01598 - Drive Battery Voltage 07-10 - Signal to Low - Intermittent Could this be anything to do with my alarm problem and what could be the actual cause of the above fault? |
| Briskoda Staff Join Date: Dec 2004 Location: Hampshire
| The code you have there is often seen following a battery disconnection. There were issues with Fabia interior monitoring units - The fix is to replace it.
__________________ Stu - Freedom Pimp Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2007 Octavia vRS, Race Blue, Xenons, Columbus Navigation, Rear Parking Sensors, Maxi Dot, Light Assist, Jumbo Box, 18" Alloys, Stu's Cruise Control & OEM Integrated Bluetooth Telephone. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - 2002 Lotus Elise RaceTech, Gunmetal, Radio, Carpet Mats. |
| Off we go Mo Join Date: Dec 2003 Location: Sussex Coast
| Just an idea about your crazy alarm, check the bonnet switch near the bonnet catch, water can get in it if it is cracked and/or the cables get chaffed in the engine bay. I think this also can play funny things with the windscreen wipers too... |
| | #5 | |
| Quote:
Cheers anyway. | |
| 6Y0 959 121 Probably about £50 ish at a guess.
| ...mmm that's no too bad a price if I get to have an alarm again. Is it simply plug and play or does it need setting up with vag-com etc? I'm collecting some parts I've ordered on Saturday, I'll get them to give me a price for the sensor then. Thanks. |
| Should be plug and play.
