Engine warning light ECM/PCM Processor
This is a discussion on Engine warning light ECM/PCM Processor within the Fabia I forums, part of the Skoda Model Discussion Area category; HI Ive got a y reg fabia 1.4 mpi 8v and my engine warning lights been on for a while, ...
Old 14-06-2008, 14:57   #1
HI
Ive got a y reg fabia 1.4 mpi 8v and my engine warning lights been on for a while, i have used a code reader and it has came up with P0606 ECM/PCM Processor.
Now i know this isnt my brake light switch as they all still work, can anyone please tell me what the problem is and how i can fix it wityhout taking it to derek slack my local rip off skoda dealer.
Yellownor is offline
Old 14-06-2008, 15:18   #2
ECUless
fordfan's Avatar
Re: Engine warning light ECM/PCM Processor
Replace the engine control module.
16990/P0606/001542 - Ross-Tech Wiki
It is possible to replace it with a used one of the same part number, however you will need the immobiliser codes for your car and the the donor car and VCDS (VAG Com) or dealer diagnostic equipment to do this. A dealer cannot get codes so will probably have to replace with a new unit and their machine will match it up electronically without them seeing the codes.
Another alternative is to replace the dash panel, engine control unit lock set and keys all from the same identical vehicle (ie all the components of the immobiliser).
fordfan is offline
Old 19-10-2008, 10:14   #3
I have this P0606 code. This was triggered by a low battery. I replaced the battery, had to reset all the OBD DTC's with a scan tool. AND reset all the VAG codes that went with this as the ECU stored all the codes with the old battery.
v_i_c is offline
Similar Threads
Engine warning light Ultimo Fabia I 2 14-06-2007 07:50
Engine warning light on hethmar Fabia I 7 13-06-2007 21:18
Engine warning light - where? wedge69 Octavia I 6 22-03-2006 10:28
Engine Warning Light Usksider Octavia I 6 19-05-2005 18:41
Engine Warning Light P.P.Power Diagnostics & VAG-COM 12 26-09-2004 18:02
