This is a discussion on Fabia steering stiff within the Fabia I forums, part of the Skoda Model Discussion Area category; As the title says, our lasses 2001 tdi estate steering has started to go stiff, this happens when you try ...
| Briskodian Join Date: Jan 2004 Location: DONCASTER
| Fabia steering stiff As the title says, our lasses 2001 tdi estate steering has started to go stiff, this happens when you try and turn quickly from the straight ahead possition, this only happens for an instant, and then is ok. Any body got any ideas before i start to panic? cheers steve
__________________ I DONT WANT TO DIE A GROWN UP! |
| Briskodian Join Date: Jun 2008 Location: Cambridgeshire
| Re: Fabia steering stiff when your driving along its ment to stop you being able to swerve big time but check the levels of power steering fluid (its in the wankest place known to man) get a funnel ![]()
__________________ ![]() Craig Laurence ![]() ![]() |
| The Following User Says Thank You to craig0031 For This Useful Post: | rigsby (21-08-2008) |
| Re: Fabia steering stiff Where mite that be? I popped the bonnet earlier and had a quick look, but didnt see a resevoir, so thought it mite be one of them electric systems
| Briskodian Join Date: Jun 2005 Location: Derbyshire
| Re: Fabia steering stiff its down near one of the chassis legs. battery side i think. as craig0031 says get a funnel, a long funnel.
__________________ |
| The Following User Says Thank You to westyRS For This Useful Post: | rigsby (21-08-2008) |
Images: 5 Thanks: 76
| Re: Fabia steering stiff Mine's doing this, mostly after a severe limited slip diff thrashing around a corner. Have yet to vagcom the car to see if it's the steering angle sensor to blame. I fear I may need a new pump as mine's now 7+ years old.
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| Briskodian Join Date: Jan 2005 Location: United Arab Emirates
| Re: Fabia steering stiff I've had that problem since the car was brand new, pump changed and everything. Kinda happens when you've made a continuous turn round a bend and then make a complete turn the opposite direction. Kinda scary when you're doin' 80km/h.
__________________ Milton Kyvernitis Private Government |
| Stiff Handbrake | Tomdeswrig | Octavia II | 7 | 22-10-2008 12:52 |
| Stiff throttle | puddener | Superb | 0 | 30-04-2008 10:26 |
| Its a bit stiff | Goodas | Fabia I | 13 | 24-01-2006 19:05 |
| Stiff rear | bengie | Maintenance & Performance | 6 | 12-12-2004 12:01 |
