This is a discussion on Fabia VRS tracking within the Fabia I forums, part of the Skoda Model Discussion Area category; Do these cars suffer with bearing to the left. Mine does and the Dealer has told me this is a ...
| Briskodian | Fabia VRS tracking Do these cars suffer with bearing to the left. Mine does and the Dealer has told me this is a common fault. Is this true? |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Re: Fabia VRS tracking I've read the same - and mine developed pull to the left after about 18months hard use...
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
Members Car: Audi S3 Thanks: 145
| Re: Fabia VRS tracking I'd say if you are concerned then have an alignment check carried out.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
Members Car: Black Magic Fabia vRS Thanks: 346
| Re: Fabia VRS tracking Both mine (vRS) and my wife's (1.4 MPi Comfy) pull to the left, and mine's had a full 4-wheel alignment, and hers had had the tracking checked. As I mentioned in another thread, I was crawling through roadworks with an off-camber and noticed that my car was pulling slightly to the RIGHT and the wheel was settling a few degrees right of dead-ahead. I suspect the Fabia is just extremely sensitive to the camber, but whatever the reason is, "they all do it"!
__________________ |
| Briskodian | Re: Fabia VRS tracking Had all this checked after Skoda changed the Stearing rack, roll bar, Bushes etc.. to find a knocking noice when the car was on fall lock. All under warrenty of course! Skoda did say there was a common fault with the cars pulling to the left, just wanted to get some views from you guys. Thanks |
| Re: Fabia VRS tracking mine was much improved after the cupra bushes - but an alignment showed the rear LH wheel toed-in, cambered over (?) and closer to the front than its fellow. Short of custom shims, I'd need a new rear beam to fix it completely....
| Re: Fabia VRS tracking Found some further info: one site claims that 'On some FWD vehicles, the rear axle can twist over time. ' wonder if pulling to the left is the axle twisting, in which case you need summat stronger or reinforced? see: Using Shims to Correct Wheel Alignment, Larry Carley, Brake & Front End, February 2000 Probably these rear camber shims wouldnt fit the fabia but the idea is good: Euro Sport - Adjustable Camber and Caster Adjusters (Plates, Shims and Bolts) for Volkswagen and Audi now if someone could locate a supplier for fabias, we'd be in business....
| 2004 Fabia vRS tracking and wheel alignment | mathepac | Maintenance & Performance | 3 | 01-11-2007 09:12 |
| Brand New VRS SE - Steering Tracking Problem + Vibrating Glove Box Lid... | simtub | Fabia I | 3 | 02-08-2007 07:25 |
| vRS tracking off? | Neilg | Octavia I | 7 | 08-12-2006 10:24 |
| Tracking figures VRS | ric04vrs | Fabia I | 6 | 14-07-2006 17:48 |
| Fabia front wheel tracking | mogwye | Fabia I | 5 | 12-08-2005 19:41 |
