Fabia vRS warm up time
This is a discussion on Fabia vRS warm up time within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi all, can anyone tell me hoe long on average their VRS's take to reach full operating temp in the ...
Old 06-12-2004, 17:31   #1
Hi all,
can anyone tell me hoe long on average their VRS's take to reach full operating temp in the morning?
Mine is taking approx 13-15 mins, of steady driving.
Im thinking thats far too long
chris-P is offline
Old 06-12-2004, 17:51   #2
Proud Dad
Chavyboy's Avatar
Sounds about right to be fair, diesels take alot longer to warm up than petrols in my experience.
2004 '54' Citroen Picasso 1.6 16v Desire HDI in Wicked Red
2004 '54' Vauxhall Corsa 1.3 CDTI Energy
Ex Skoda owner
Chavyboy is offline
Old 06-12-2004, 17:52   #3
ah i see, thot maybe something was wrong, will have to invest in gloves
chris-P is offline
Old 06-12-2004, 17:55   #4
robmawer's Avatar
Is there not an auxiliary heater on the Fabia diesels to get the cabin warmed up quicker?
Rob.
robmawer is offline
Old 06-12-2004, 17:56   #5
robmawer, i dont think so? unless anyone knows different?
chris-P is offline
Old 06-12-2004, 17:57   #6
Proud Dad
Chavyboy's Avatar
Not seen one TBH.
Ex Skoda owner
Chavyboy is offline
Old 06-12-2004, 17:58   #7
robmawer's Avatar
Well, it might not, it's just something I'd come across on other diesels, so wondered if the Fabia has one...
Looks like you might be looking a pair of gloves then! Or one of those little bar heaters which stick on the dash and plug in the ciggy lighter socket...
Rob.
robmawer is offline
Old 06-12-2004, 18:00   #8
hahah, looks like it, maybe a hot water bottle 2, makes short trips horrible!!!
chris-P is offline
Old 06-12-2004, 18:34   #9
Cupra Bush King
Lummox's Avatar
Images: 2
The Fabia has both cooling system pre heaters and a electric heater for the cabin next to the heater matrix.
However they aint fitted to UK spec cars....bugger!
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is offline
Old 06-12-2004, 18:44   #10
Fabian
bryand's Avatar
Slow warm-up
I'm having the same problem - a particularly noticeable slow warm-up time, during which my Furby drinks diesel like it's OPEC Benefit Week.
I'm partway through the install of a Kenlowe HotStart system - will post details and stats when it's done. (Electrics finished; dealer is doing the plumbing on friday)
bryand is offline
Old 06-12-2004, 18:52   #11
dsemuk's Avatar
My much hated a-class had a diesel heater, only worked when outside temperature dropped below about 6 degrees...
Bit embarrasing when sat in a queue of traffic on cold moring as it sounded like the car was powered by a jet engine, but it warmed the cabin up in no time, I didn't use a drop of de-icer in the four or so years I had the car.
I miss that heater, especially as my commute to work is now only 4 miles so glovers are essential on these cold mornings
dsemuk is offline
Old 06-12-2004, 19:38   #12
Escorted Estate
Any way you could import say from Holland with that spec'd already?
WW_VRS is offline
Old 06-12-2004, 19:47   #13
SimonT's Avatar
Or retro fit?
Si
SimonT is offline
Old 06-12-2004, 19:48   #14
SimonT's Avatar
How about an electric engine block pre-heater? I understand that some people swear that these increase engine longevity, although I don't know how well any gain weighs up against the energy costs of heating the block. Whatever, it might get the heater working sooner but perhaps the sledgehammer approach?
Si
SimonT is offline
Old 06-12-2004, 19:56   #15
Om nom nom nom
Neo_VR's Avatar
The passat i had at the weekend had heated seats... quite nice when its feckin freezing outside. i can see their possible use on a furby.. but it didnt matter on the passat as it warmed up quick due to me thrashing it
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 06-12-2004, 20:06   #16
helpmedisappear's Avatar
On some mornings on my 10 mile commute the engine is only half warmed up. Ive also seen the temp needle drop when i start moving from a jam which was very strange
Martin
Black Magic Fabia vRS
v
helpmedisappear is offline
Old 06-12-2004, 20:17   #17
Cupra Bush King
Lummox's Avatar
Images: 2
Temp needle could well drop as when you start moving again air starts flowing through the rad again coolong the water back down, temp will also drop after the intail heat build up when the thermostat opens and lets water flow around the system.
The ASV type injection pump diesel had cooling system pre heaters for foriegn markets, much like a glow plug there were three of the sat down the side of the cylinder head in the top hose.
Never timed it but my car is normally getting hot by the time ive reached J15 on the way to work which isnt more than a couple of miles. Needle is usually on 90 degrees by then and the heater is just starting to get warm.
www.unit18.co.uk
Lummox is offline
Old 06-12-2004, 21:24   #18
Heated Butt
Have the heated seats in my VRS, have to say worth every penny..................particularly as I didn't have to pay for them.
May the Funk be with you undefined
Black Magic VRS with lots of toys, Red Dragon box, green filter, pd160 intake and pikey mods, dip and main beam upgrades.
FunkySi is offline
Old 06-12-2004, 21:49   #19
rossm's Avatar
Heated seats are an excellent option, well worthwhile! Had to pay for mine, but at £125 its a complete bargain, especially at this time of year! I got the Furby in June so didnt really appreciate how much I would use them, but I just leave them on midway setting all the time just now, and they warm your *** within seconds. Don't use the dashboard vents for heating the car at all, seats warm me up enough.
As far as the engine temperature is, I would say its changed a lot now its winter, it used to be up to about 90 in about 2 mins. Now it takes a bit longer, say about 5 mins to get there. I've never timed it exactly, but 10-15 mins seems a bit much. I will watch mines tomorrow morning and see how long it takes.
rossm is offline
Old 06-12-2004, 21:59   #20
i noticed that once the car is warmed up it stays warm for a lot longer than a petrol once the engine has been switched off
"I am not bothered about the smoke that comes out the back of my car" I'm not behind it
gingerVrs is offline
Old 06-12-2004, 22:09   #21
logiclee's Avatar
My Octy warms up a bit quicker than my wifes Furby but they both still take ages. My last two cars Scooby and Rover 75 V6 warmed up very quickly but with the fuel they used you could have set fire to a small forest.
I had a Rover 75 CDTi as a loaner last winter and that had a diesel cabin heater, you could set a timer in the arm rest for the time you wanted it to come on. Alternatively it came with a remote control with 300 metre range so when you got up in the morning you just pointed the remote at the car outside and by the time you had eaten your breakfast the car was defrosted and the interior lovely and warm. Didn't seem to use much diesel either.
Cheers
Lee
Another Ex-Scooby owner.
Mondeo TDCi 130 6 Speed Ghia, Octavia 1.9TDi Elegance (Now Sold), Fabia 1.9TDi Comfort and Felicia 1.9D GLi
logiclee is offline
Old 07-12-2004, 11:08   #22
so guys how long did they take to warm up this morining?
chris-P is offline
Old 07-12-2004, 11:12   #23
robmawer's Avatar
My diesel didn't hit normal operating temperature at all...too much traffic...
Rob.
robmawer is offline
Old 07-12-2004, 12:01   #24
Om nom nom nom
Neo_VR's Avatar
Cheers
Lee
now that IS cool
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 07-12-2004, 15:19   #25
Escorted Estate
Any reason these heaters couldn't be retro-fitted?
WW_VRS is offline
Similar Threads
Introduction to the Fabia ColinD Fabia I 17 17-12-2007 14:11
Waiting Time for Fabia vRS? rob1sp Fabia I 38 17-08-2004 18:09
Another Fabia Vrs Review flyingscot General Car Chat 4 15-08-2003 19:37
Evo Review Of Fabia Vrs SilveRS General Car Chat 7 30-07-2003 14:18
