A valued partner and supporter of this community, please visit.
This is one of our valued partners, please consider supporting them.
Fabia VRS - Worsening Ride Quality
Discussing Fabia VRS - Worsening Ride Quality within the Fabia I forums, part of the Skoda Model Discussion Area category; Hello all. Having problems with my Fabia VRS with regards to ride quality. Now, I got the car this time ...
Login
46,768 Members 15 Posts
Notices
Register to reduce ads, enable search and join our community.
Bookmark and Share LinkBack Thread Tools Display Modes
Old 26-08-2008, 17:34   #1
ultra_joel88's Avatar
Members Car: 04 Fabia vRS (180/300)
Hello all.
Now, I got the car this time last year, and although I would never by any means describe the ride as "superb", its definitely passable on 90% of road surfaces.
However over the past couple of weeks it feels as though it has got noticably worse.
Where as before the car would ride fairly well on roads I travelled everyday, now it seems to be picking up every tiny little dint on the road, and this is vibrating all the way to the seatbase and even through the steering wheel
I have just had the 4 year service. The mechanic told me that the right rear caliper was sticking a little bit, but surely it cant be down to this? I have touched the offending wheel after a 1/2 hour drive and it is not getting any hotter than the other wheel, though there is some stickage there as when I washed the car there was more brake dust on that side.
The car is standard apart from a SEAT strut brace and whiteline ANTI ROLL BAR. The bar has been fitted for around 4-6 months and is on its stiffest setting - it cant be this as this has only come about in the past week.
I have also noticed that my rear suspension has started creaking - especially when the handbrake is applied and when getting in and out of the car.
Help appreciated.
They've gone... to Longstanton Spice Museum.
ultra_joel88 is offline
Old 26-08-2008, 17:47   #2
Vanishing Point
Wardy's Avatar
Location: Usually somewhere around Manchester or Cheshire...
Members Car: Octavia vRS 2.0TFSi
Images: 6
Re: Fabia VRS - Worsening Ride Quality
Are you running standard springs and dampers Joel? How many miles has the car done?
Steve
18s : Maxidot : Jumbo Pack : Cruise : PDC
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is offline
Old 26-08-2008, 17:50   #3
Sorry, meant to say that.
Yes I am running standard springs and dampers. The car has done 41k
Old 26-08-2008, 17:57   #4
Vanishing Point
Wardy's Avatar
Images: 6
OK, and are you on original suspension bushes? With the front of the car jacked up, I'd check for play.
Depending on the life the car's had, and the standard of the roads travelled, it could well be a sign that the dampers and/or bushes are past their best.
Just a thought....
Steve
Wardy is offline
Old 26-08-2008, 18:28   #5
How would I tell if the bushes are gone? I am still on the original bushes - the crap ones with the "voids"
Old 26-08-2008, 19:35   #6
KTP
Sump Assassin
KTP's Avatar
Members Car: Fabia vRS
Images: 1
by jacking it up, grabbing the wheel with both hands and see if you get any movement that shouldnt be there.
Take a look to the sky just before you die, it's the last time you will...
Buy Stickers HERE!
KTP is offline
Old 26-08-2008, 19:39   #7
Happy
vRSLen's Avatar
I notice you quote ride quality rather than steering/handling issues. I would suspect that
the dampers may have go off.....
Current car: Black MKII Octavia vRS Combi
Previous: Black MKI Octavia vRS Combi
Black Fabia Elegance 100 BHP
vRSLen is offline
Old 26-08-2008, 20:39   #8
Dexterous's Avatar
Members Car: Fabia VRS
I'm having similar issues with poor ride quality. Starting to get a lot of clunking noises from the front and back now.
Its going in for a service next week so I'l get it looked at then!
Mines done 60k btw
Dexterous is offline
Old 26-08-2008, 20:41   #9
Vanishing Point
Wardy's Avatar
Images: 6
I'd be fairly sure that clunking would be suspension bush related, but as you say - get it checked. But if they do need changing, make sure the ones to the rear of the wishbone are replaced with solid Ibiza Cupra ones!
Steve
Wardy is offline
Old 26-08-2008, 21:12   #10
My mechanic said to me that although he generally rates VAG cars and the engines will go on forever - on the ibiza/polo/fabia range especially he said that the driveshafts and suspension get a bit sloppy after around 60k.
Old 27-08-2008, 01:59   #11
KTP
Sump Assassin
KTP's Avatar
Images: 1
i had my bushes replaced at last mot as they were buggered.
3yr old car with less than 30k on the clock at the time
Buy Stickers HERE!
KTP is offline
Old 27-08-2008, 11:34   #12
would they affect the ride quality?
Old 27-08-2008, 12:15   #13
Members Car: vRS Fabia
It sounds like your dampers are getting tired. Bas reported his standard ones were knackered a while back. The ride quality is getting harsh on my 04 vrs with 48k but I've got Eibach springs and I think they have killed the OEM dampers.
Rich - Black Magic Fabia vRS
vrsfab is offline
Old 27-08-2008, 14:01   #14
Vanishing Point
Wardy's Avatar
Images: 6
Arrow Re: Fabia VRS - Worsening Ride Quality
Can you confirm, quality is noticeably worse, as opposed to cornering and steering feel?
If it's the former, I'd say the dampers need replacing.
Steve
Wardy is offline
Old 27-08-2008, 15:24   #15
vindaloo's Avatar
If it's buzzing or similar, then maybe look at tyres and wheel bearings. I think, particularly if you've swapped previous front tyres to the rear. No reason than they'll be that much older than the fronts.
Rattling etc would probably be one of FARB droplinks, FARB location collars, front suspension bushes...
J.
Slowly turning the planet sooty.
vindaloo is offline
Bookmarks
Similar Threads
What the first step in improving Fabia VRS sound quality? Kaiserb_uk ICE, Security and Insurance 1 01-03-2008 00:18
Why does the Fabia VRS ride and handle better thewez Fabia I 13 02-09-2006 00:40
Ride Quality New Octavia johnbull Octavia II 32 31-08-2006 22:40
Ride/noise Fabia vRS/Octavia vRS john banks Fabia I 4 30-11-2004 12:26
Octavia Vrs Ride quality bazzer General Car Chat 15 01-04-2004 19:10
Disclaimer: This is not an official SKODA site and is not affiliated to SKODA in any way. Visit the Official SKODA Website. Views and opinions are given by the poster and do not reflect the views of BRISKODA.net nor SKODA.
PLEASE NOTE - PERSONAL ABUSE, ABUSE AGAINST THIS OR ANY OTHER WEBSITE OR ANY COMPANY WILL NOT BE TOLERATED. OFFENDERS WILL BE MODERATED OR EVEN BANNED.
BRISKODA.net is operated by Summit 360 Ltd. Site Design and vBulletin Theme by Alex Pinner (apinner)
Problem viewing this site? Upgrade to the latest version of your web browser of choice:
Opera | Firefox | Safari | Internet Explorer
Website © 2002-2009 BRISKODA ltd & SUMMIT360 ltd E. & O.E.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
