This is a discussion on Fog lamp grill replacement within the Fabia I forums, part of the Skoda Model Discussion Area category; Has anyone ever had to replace a drivers side foglamp grill? I need to replace a missing one and before ...
| It's all good Join Date: Oct 2005 Location: Cwmbran - South Wales
| Has anyone ever had to replace a drivers side foglamp grill? I need to replace a missing one and before I run to the stealers I was wondering if anyone has paid Cahs Monies for one before and roughly how much? Do the grills have to be sprayed? Cheers |
| | #2 | |
| Briskodian Join Date: Oct 2005 Location: SW UK
| Quote:
| Apologies, it's a Black VRS. Don't suppose anyone would have the part numbers? |
| | #4 | |
| Quote:
However, looking at my past bills (and having to do a bit of guesswork as the descriptions aren't too good).... For the black grille try: 6Y0853684AB41 O/S F/L GRILLE £5.53 and the colour coded cowl that actually goes around the light might be either: 6Y0853655A or 6Y0853656A (presumably depending on the side) £3.08 I'd only use those numbers as a check though - you're better off telling the parts person what you want and let them look it up, that way if the wrong bit turns up it's their mistake and you don't have to pay. | |
