This is a discussion on Gas is working! within the Fabia I forums, part of the Skoda Model Discussion Area category; It's all up and running now. However the side effect is I think it needs to be tweaked elsewhere to ...
| Mongreller Join Date: Apr 2003 Location: Ooo-ar, Oi be from Devonshire
| It's all up and running now. However the side effect is I think it needs to be tweaked elsewhere to get it to work as it really should. I'm not seeing much increase in power and its only marginally less smokey with it on, The engine sounds quieter with lpg injecting when its boosting/revving up, so it could very well be working more efficiently now lpg is going in with the air. No leaks when it was tested, aside from joint that I'd done. but that only required one turn with a spanner to seal. ![]() All in all, I'm very happy. Just waiting now to see what kind of economy benefits I get from it. Oh, and I need to sort that bracket out too.
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. See the mongrel's 260bhp Dyno Video! |
| Worthless loser Join Date: Jan 2005 Location: Nowhere of interest to anybody
| No big explosions then - was hoping to see on the news that half of Devon had been destroyed by a massive unexplained explosion ![]()
__________________ David 2002 Black Magic Octavia V/RS |
| | #3 | |
| Quote:
__________________ John Take away the poor damping, inadequate bushes, heavy diesel lump and spongy brakes its not a bad warm hatch | |
| Briskodian Join Date: Jan 2005
| "Economy benefits"? TV rights to the video? Glad to hear you, car and Devon are in one piece, Jason. What exactly are tenterhooks? Been on 'em long enough. ![]() Mo |
| Briskodian Join Date: Feb 2006 Location: Essex
| I was watching a programme about Pompeii the other day, and I did think of you Jason.
__________________ |
| Old Git Join Date: Oct 2004 Location: Wiltshire
| I think Jason and the person riding this bike have a lot in common http://www.briskoda.net/forums/off-t...-stupid/56764/ No not speed ........both of them sat on a tank of gas ![]() |
| Well, I'm pleased its working. Had the ultimate tester - a head gasket pump test kit attached to the boost line, and you could find out exactly when it cuts in (desd on 5psi) and he was able to push the gasket kit to 2 bar to show the rate of gas flow at that level of pressure - PSSSSSSSSSTTTTTTTTTT! Was very fast! Actually ended up turning down the grub screw to about 4/6 of maximum as they'd sent it to me on max flow setting bearing in mind the "do not use full lpg injection rate as it might cause engine detonation in the cylinders....." (or something like that)Time will tell. Have a feeling I'll be on the phone to Jabbasport in the week if I really do not feel any power gain. ![]()
| | #8 | |
| Quote:
__________________ David 2002 Black Magic Octavia V/RS | |
| Both sound equally as bad, but I can't remember the precise term used. It was something like "engine-knock."
| | #10 |
| Would be pre-ignition then - almost as bad as an outright BOOM! not not quite ![]()
| | #11 |
| Too much gas can cause bad stuff - I dont know the right term either but it isn't great ![]() I'd imagine I noticed a far bigger increase in power due to being on a phase 1 generic map, the LPG made a good difference there but smoke wise not too much difference compared to a remapped car apparently ![]() Fuel economy should be better if you don't cane it - be interesting to find out once it's properly retuned with gas ![]() |
| | #12 | |
| UberMod™ Join Date: Feb 2003 Location: Manchester
| Quote:
__________________ ColGod the UberMod ![]() VXR, Gti, ST, Type-R, vRS, Shifty... An MPS fears not these things... ![]() ![]() | |
| | #13 | |
| Quote:
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. See the mongrel's 260bhp Dyno Video! | |
| | #14 | |
| Quote:
there can be when your sticking in a petrol like fuel ![]()
__________________ owner of a skoda octavia 4xvrs3 | |
| | #15 | |
| Quote:
| | #16 |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| You can get pre ignition on a diesel, if the fuel is combusting before TDC then the piston is going to try and go down when the crank is still trying to push it up.
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| | #17 |
| "Bones" Join Date: Jan 2004 Location: Heathrow/Crewe
| Hope you get it all working 100% Jay, should be interesting come Ring time! Ross I still stand by my comment of today lol ![]()
__________________ Oh to have the internet back..................oh have I missed it |
| | #18 |
| Well, the gas "may" have blown something. I suspect the exhaust is blowing somewhere near the turbo, or the actual exhaust manifold has shot. Hope to find out tomorrow. ![]()
| | #19 |
| Within in a few days...............dang I was right then just joking mate, I hope you get it sorted very soon!
| | #20 | |
| Quote:
Hoping its a coincidence, but I was warned using lpg would raise exhaust gas temps, so it might be that....
