This is a discussion on heated mirrors within the Fabia I forums, part of the Skoda Model Discussion Area category; i have heated mirrors on my vrs, or should i say heated mirror! should i have two. only the drivers ...
| Briskodian | heated mirrors i have heated mirrors on my vrs, or should i say heated mirror! should i have two. only the drivers side gets hot. if im supposed to have two any ideas why the near side would stop working? |
| Briskodian Join Date: Feb 2007 Location: HEREFORD
Members Car: SKODA FABIA vRS Thanks: 2
| Re: heated mirrors i have the same problem but on the oposite mirror took it to the dealers and they said it was fine, but still dont work
__________________ 07 Fabia vRS,/// Cruise Control, De-Bump striped, Seat Leon Front Splitter, Seat Sport Front Strut Brace, PD160 Air Intake and Green Cotton Air Filter, Cage mod, Uprated indicator Bulbs and Headlight Bulbs, LED sidelights, Ipod Interface, Jabba Sport ARB, Turbo back, and SportCat Milltek Exhaust, JABBA Sport Custom Remap! 312mm Brakes, Eibach Pro-Kit Springs Privacy tints all round, and Anthracite Octy 17" Spiders and sticky Toyo Proxes T1R rubber! To come Leather retrim, Forge FMIC! |
| Briskodian | Re: heated mirrors would think they are on the same fuse.gonna go and look. |
| Re: heated mirrors ye i think so
| Briskodian | Re: heated mirrors in manual it says heated exterior mirror. not mirrors as it says for adjusting L/R exterior mirrors. |
Members Car: Fiat Panda Thanks: 15
| Re: heated mirrors Could it just be the element in/behind the glass has burnt out? Pretty sure both are fused together so any problem in the circuit would stop them both working. Chris
| Briskodian Join Date: Jul 2006 Location: milton keynes
| Re: heated mirrors I have a VRS and both sides get warm when defrosting in the mornings on the drive.
__________________ Black Fabia Vrs, PD160 air intake, Pipercross filter, Aero Wipers, Phillips 80% extra bulbs |
| Briskodian Join Date: Jan 2007 Location: West Yorkshire
Members Car: 05 Fabia vRS Thanks: 3
| Re: heated mirrors Mine were on for the first six months I had the car as I didn't realize the middle position wasn't just the off position. Both still working, but I wish there was a proper off position as my learners always switch it to the middle and I sometimes still don't notice until I readjust them for me after the lesson. I've thought about fitting a secondary switch but can't be bothered.
__________________ Diesel - Goes like stink |
Members Car: '04 Red Fabia vRS Thanks: 24
| Re: heated mirrors Don't they turn off after 20minutes anyway??? (or did I just imagine that? )
__________________ |
| | #10 | |
| eeeeeeeeevil. | Re: heated mirrors Quote:
![]() that means mines have been on since i got the car aswell.
__________________ | |
| | #11 |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: heated mirrors There is no mention of this in the Owner's Manual. Perhaps you were thinking of the heated rear window which does switch off automatically after 20 minutes, unless you then press the switch once again in which case it is switched on permanently, ie the automatic deactivation is then deactivated.
| | #12 |
| Briskodian Join Date: Jun 2005 Location: Kirkcaldy, Fife
Members Car: E46 330d Sport Thanks: 1
| Re: heated mirrors Aren't the mirrors only on when the rear window is on? (and obviously the switch is in the center position). This was certainly the case with my Golf. |
| | #13 |
| Hiya Vic!!! Join Date: Feb 2006 Location: Sheffield, South Yorkshire
Members Car: 2006 Fabia vRS & 2005 Fabia vRS. Images: 9 Thanks: 116
| Re: heated mirrors Having had the same setup on the polo before i got the vRS..... It has always been a case of when the mirror adjuster switch is in the middle the wing mirrors heat up while the ignition is on. If you move the switch to one of the wing mirror positions it switches one of the mirror heaters off. As i say this is how it worked on the Polo and also how mine work on the vRS... In fact on both our vRS's. The MG ZS we used to have worked the same way but the Lexus we used to have a couple of years ago had a little button to switch the heated mirrors on/off as reqd. HTH Cheers Dave. |
| Heated Door Mirrors | dibbley | Octavia II | 29 | 29-11-2008 11:55 |
| Heated Mirrors | Organist | Octavia II | 14 | 06-03-2008 18:40 |
| heated side mirrors | FlukemanStu | Fabia II | 13 | 11-10-2007 08:17 |
| Timer for heated mirrors.... | Neily03 | Diagnostics & VAG-COM | 5 | 29-07-2007 16:59 |
| Doah, heated mirrors always on!! | ffvrs | Fabia I | 18 | 21-05-2006 10:06 |
