This is a discussion on HELP ME PLEASE....Power Steering Sensor problem within the Fabia I forums, part of the Skoda Model Discussion Area category; If any one can help me to find out why when I drive, the power steering warrning light comes on ...
| Briskodian Join Date: Mar 2007
| If any one can help me to find out why when I drive, the power steering warrning light comes on with head light start flicking especially at end of the journy, then I loos the power steering. I went to skoda dealer they told to change the power steering sensor which cost £155. by the way I don't have the manual book! Thank you for your help........ ![]() |
| Briskodian Join Date: Jun 2006
| Common fault - Do a search on PAS sensor |
| Briskodian Join Date: Jan 2007 Location: Suffolk coast
| chap on ebay sells them £40 get a local garage to fit for about £40 saved yourself a few quid or if your up to it DIY. I had mine done the same simptons as yours no fine after sensor replacment. |
| Thank you KTea88 and Joey122mac for your help and reply. |
| Briskodian Join Date: Jul 2006
| This happened to mine (2001 1.4 8v classic) headlights flickering, dash light flickering and power steering light showing. took it back to dealer who sent it back to skoda. They replaced sensor and problem solved however watch for the heating system as mine had to have thermostat replaced very soon after.If your garage replace heating sensor then they should replace the whole thermosat too. by the way does your power steering go very heavy at slow speeds mine did before fixing and yes luckily I bought another warranty |
| Dervlova Join Date: Apr 2005 Location: Cloud cuckoo land
| The seller on ebay's upped his prices... Was £40 eBay.co.uk: SKODA FABIA SEAT IBIZA POWER STEERING YAW ANGLE SENSOR (item 120088786694 end time 26-Feb-07 08:50:42 GMT) Now £50... eBay.co.uk: SKODA FABIA SEAT IBIZA POWER STEERING YAW ANGLE SENSOR (item 120094284024 end time 15-Mar-07 18:04:03 GMT) ![]() |
| Thanks Joff I bought the sensor just now the one you mensioned from eBay for £50. Thank you Mark raw for your advise. ![]() |
