This is a discussion on Help for New Forum member within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi everyone , can you help me? I need a manual of some sort , like Haynes but not sure ...
| Briskodian | Hi everyone , can you help me? I need a manual of some sort , like Haynes but not sure if any avail? i have a 2000 Fabia 1.9SDi Estate. Can anyone advise on removal of rear Drum Brake housing to replace Shoes as mine is loose after removing centre nut but will not come away!! Anyone else had problems with tyres scrubbing at front inside edge, i have had tracking done by several garages but still get the problem after a few months!! Think that's it for now... Many Thanks Martin |
| Briskodian | regarding removal of the drum it probably just needs a hammer tap around the edge (from the front , not the side ) due to a lip been formed where the drum has worn. as for tyres it does sound like a tracking issue , try and get it optically tracked maybe , i dont trust those crappy metal ones they dont compensate for wheel distortion. btw sdi estate owner aswell ( vrs estate soon maybe???) ![]() |
| Drum removal. You dont need to undo the nut. Remove the screw and the drum comes off and the hub stays there. If the drum is stuck on the rust ridge move the drum so a bolt hole is at around the 10 o clock position. Have a look thru it with a torch and you should see a light grey piece of metal with a spring attatched to the end of it. Witha flat blade screwdriver flcik that bit of metal up. This will de adjust the brake shoe adjuster and enable the removal of the drum. |
| Briskodian | Thanks guy's, does anyone know where i can get a manual like Haynes? |
| | #5 | |
| Ding, dong Join Date: Sep 2003 Location: in the doghouse
Images: 4 Thanks: 4
| Only from Skoda. Haynes do not do a manual
__________________ Jeff: Ambitious, but rubbish Quote:
| | #6 | |
| Fabian | Fabia DIY manual Quote:
The bad news is that it's in German... (see http://www.briskoda.net/forums/t1259...s-manuals.html) A bit of BabelFishing often helps! | |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Looks like there are 2 German manuals for the Octavia too: http://www.amazon.de/exec/obidos/ASI...104991-9922147 http://www.amazon.de/exec/obidos/ASI...104991-9922147 PS Only slightly off topic...
| Briskodian Join Date: Jan 2007 Location: Cardiff
Members Car: 1.9 Fabia SDI Thanks: 0
| Re: Help for New Forum member Slackening the handbrake cables at the handbrake end also helps when removing the rear drums. I could not find the lever through the bolt hole and could not slacken the shoes other than by slackening the cables. |
| | #9 | |
Images: 4 Thanks: 4
| Re: Help for New Forum member another resurrected 2 year old thread. also there is now a haynes manual for the Fabia closed.
| How mant forum members does it take to change a light bulb? | roo | Off Topic and Chit Chat | 15 | 21-06-2005 20:46 |
| Other car forums chat | fab16v | Off Topic and Chit Chat | 2 | 12-10-2004 07:53 |
