This is a discussion on hmmmm clutch slipping? within the Fabia I forums, part of the Skoda Model Discussion Area category; my friend took my car for a spin about a week ago, and he went to pull away up a ...
| Briskodian Join Date: Feb 2005 Location: A30 Newquay Cornwall
Members Car: Fabia 1.9 TDI Thanks: 39
| hmmmm clutch slipping? my friend took my car for a spin about a week ago, and he went to pull away up a hill.... revved it like a bitch and the reves kept going up but the speed was really slow.... i dont seem to feel the effect as much as i guess i change out of 1st pretty quickly... he also said it felt quite... "mushy" rather than bitey it all worked smoothly rather than a bite and go kinda feel.... now is this the clutch? or soemthing? theres a bigger whirring noise now and im getting really annoyed with the noise in neutral! how much will this cost by the way ![]()
__________________ ![]() Fabia Bohemia Mods - 16" BBS Montreal's, Blaupunkt Rome nav, fitted front and rear areo wipers, rear OEM speakers fitted, vw damped grab handles. |
Members Car: Black Magic Fabia vRS Thanks: 346
| Re: hmmmm clutch slipping? Clutch slip is more apparent when flooring it at low revs in high gears, so I doubt it's that. If you want to check, stick it in top at about 30mph and floor it. Very little ought to happen, and most importantly the revs shouldn't rise by much... But the fact that the car feels 'different' suggests something's happened...
__________________ |
Members Car: Fabia 2.0/Felicia Thanks: 48
| Re: hmmmm clutch slipping? mine did the same leon.... the release bearing had worn a groove into the pressure plate fingers and it made a horrible whirring noise |
| Re: hmmmm clutch slipping? anyway of fixing this? it makes the dodgy noise in 1st too!
Members Car: silver Fabia VRS Thanks: 31
| Re: hmmmm clutch slipping? gearbox out and a new clutch assembly required by the sounds of things ,
__________________ not so bored now |
| | #6 | |
| Re: hmmmm clutch slipping? Quote:
__________________ ![]() Fabia Bohemia Mods - 16" BBS Montreal's, Blaupunkt Rome nav, fitted front and rear areo wipers, rear OEM speakers fitted, vw damped grab handles. | |
| Briskodian Join Date: Sep 2006 Location: Walsall
Members Car: Leon TDI DSG or Lupo 16v Sport Thanks: 110
| Re: hmmmm clutch slipping? That's a fair life for a clutch. |
| Re: hmmmm clutch slipping? the release bearing could collapse/break-up and cause more damage due to bits bouncing around the bellhousing, plus do you really want to be stuck at the side of the road and have to have the car towed to the garage , do you have AA/RAC cover ?
| Re: hmmmm clutch slipping? hmm thats a good point, i got RAC yeah with Barclays. ill have it checked out tomorow.
| | #10 |
| Briskodian | Re: hmmmm clutch slipping? he he that happened to my old car needed a new clutch and tried to hold out until I traded it in it finaly died in the middle of rush hour on the main rd in town the night before trade in day. What a nightmare managed to block the traffic up in town until I finally got it pushed to a side street lots of burning and nasty smells as well. Then turned up at my new dealers with it on the back of a tow truck whoops!!!! That taught me to never try and hold out and get things done asap. |
| | #11 |
| Re: hmmmm clutch slipping? will anyone be able to fix it before friday you recon? ie quickfit?
| | #12 |
| Re: hmmmm clutch slipping? mine went at about 80k too... dont get quicky fix to do it.... they will most likely bodge it |
| | #13 | |
| | #14 |
| Briskodian Join Date: Jan 2006 Location: Newport
Members Car: Yellow '54' Fabia vRS Thanks: 9
| Re: hmmmm clutch slipping? I think it's a common misconception now that dealers charge too much... Usually you can be very surprised by the costs and at least you know the work is done 'properly' (within reason) even if it does cost a touch more.
__________________ ![]() Yellow 54 Plate vRS - Revo Technik Remap - Eibach Suspension - Sachs Paddle Clutch - Gloss Black Porsche Design 90s. South Wales Freshest VAG Meet - www.newportedition.com |
| | #15 | |
there only just up the road. ![]()
| | #16 |
| Re: hmmmm clutch slipping? well they had a look and its something to do with something that makes changing gear easier... nothing to worry about... there gonna check my gear box fluid too to see if thats ok. another thing the break warning light will come on when my pads are low wont it? its only once or twice i can hear some metal to metal kinda thing.... hmm ill ask that tomorrow too! haha. other than that car seems to be fine! ![]()
| | #17 |
| Re: hmmmm clutch slipping? I think that may only be Elegances - so it'll depend what kind of Fabia you have!
| | #18 | |
| | #19 |
| Re: hmmmm clutch slipping? the brake warning light is tells you the fluid is too low doesn't it?? could explain your gearchange problems too! |
| | #20 |
| Briskodian Join Date: Jul 2006 Location: Nottingham
Members Car: A lovely unadulterated Fabia vRS Thanks: 4
| Re: hmmmm clutch slipping? How to build a good relationship with your dealer - don't pay what you owe. Cute.Very cute. |
