This is a discussion on How to split glovebox lid within the Fabia I forums, part of the Skoda Model Discussion Area category; Ok folks - has anybody slit the inner and outer skins of theier glovebox lid to get at the mechanism. ...
| Briskodian Join Date: Dec 2002 Location: Sheffield
| How to split glovebox lid Ok folks - has anybody slit the inner and outer skins of theier glovebox lid to get at the mechanism. Mine has started rattling like a b***ard in this cold weather and it's the mechnism inside that needs a bit of packing/spongey stuff around it. I've had the lid off and had a poke with a screwdriver but could do with knowing where the clips are so I don't break anything and make it worse. Cheers
__________________ If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables! Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS Last edited by skomaz; 27-11-2007 at 16:29. Reason: I can't spell!!!!!!!! |
Members Car: silver Fabia VRS Thanks: 31
| Re: How to split glovebox lid its bonded together , i tried to get my first lid apart but it was impossible without actually wrecking it , also tried packing it out around the edges , it still rattled luckily mine was still in warranty and i got a new one for free , unfortunetely this is now rattling , ahhhhhhh
__________________ not so bored now |
| | #3 | |
| Re: How to split glovebox lid Quote:
Bonded was what I thought given my initial inspection and wasn't what I wanted to hear I have already tried adding stick on rubber stops to the edges to try and take up some of the slack in the mechanism and was hoping to split it to put some flet type material between the mechanism and the skin. The rubber stops have worked for about 5 years but now I need something extra. Looks like I'll have to find an alternative method!
__________________ If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables! Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS | |
| Re: How to split glovebox lid fill it full of spray foam ![]()
| Re: How to split glovebox lid Hmmm... Not such a stupid idea if I coudl only be certain that the mechanism wouldnt stick as well! Maybe soem thick spray grease might work?
| | #6 | |
spray grease might be worth a try , or even motorcycle chain lube , that stuff is super sticky
__________________ not so bored now | |
| Briskodian Join Date: Sep 2004 Location: Bristol UK
Members Car: Skoda Fabia 2.0 Elegance 04/2005 Thanks: 0
| Re: How to split glovebox lid Aha, so it's the lid! I thought it was something inside my glove box. When I open it and have a poke around inside, it seems to go - for a while. So what causes the rattle - the hinge bits? |
| Re: How to split glovebox lid No it's not the hing it's actually the mechanism for holding it shut that is inside the lid that rattles. It seems to consist of two bars running across the lid to the handle and in my case these appear to be rattling against the outer skin of the lid.
| | #9 | |
I presume those bars would not be steel. otherwise bonding a small magnet on the inside could help - assuming it is the outer skin they are rattling against. | |
| | #10 | ||
I think the best shot is as suggested above - something pretty sticky/gloopy like white lithium grease that can be sprayed inside the lid and will stay in place but is sticky/gloopy enough to stop the mechanism moving until the handle is used.
__________________ If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables! Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS | ||
| | #11 |
| Re: How to split glovebox lid Ok well I still haven't tried the spray grease or chain lube but have had some success with an additional rubber stopper. It's placed dead central on the glovebox lid on the lid itself at it's top edge where it meets the main dashboard. It hasn't completely cured the rattle but has lessened it significantly by putting a small amount of "flex" into the lid that appears to be taking up the majority of the slack inside the lid and thus reducing the rattle.
| HELP! boot lid sensor | omniped | Maintenance & Performance | 2 | 28-08-2007 20:27 |
| Octy II - Ash-tray lid won't close | andy2407 | Octavia II | 8 | 10-08-2007 15:18 |
| Stiff boot lid | DaveC | Superb | 7 | 04-02-2006 15:04 |
| Boot Lid and Rain... | Martin Keene | Octavia I | 10 | 20-08-2005 23:34 |
