interesting article on IC mods
This is a discussion on interesting article on IC mods within the Fabia I forums, part of the Skoda Model Discussion Area category; Check it out: http://autospeed.drive.com.au/cms/A_...popularArticle Perhaps converting the original air-air SMIC to a water-jacketed system is the way to go.... An ...
Old 05-07-2006, 17:40   #1
hardcore modder
Basil's Avatar
Smile interesting article on IC mods
Check it out:
An interesting fact is that water carries away 4x more heat than air. So if you made the OEM SMIC 4x more efficient, then it's better than a FMIC.
I'd love to hear some comments please
Cheers
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 05-07-2006, 17:45   #2
splash!!!!
bengie's Avatar
Default Re: interesting article on IC mods
the water may absorb 4x the heat as air but it also has to get rid of heat at the same rate so probably no moe efficient than an air-air IC
most companies only go for charge coolers when they are limited with room or the engine is at the back of the car.
owner of a skoda octavia 4xvrs3
bengie is offline
