This is a discussion on Just changed brake pads and... within the Fabia I forums, part of the Skoda Model Discussion Area category; My left front brake (passenger side) last night started to make a hideous grinding noise, anyway as JBS suspected my ...
| Briskodian Join Date: Jun 2004 Location: Leeds, West Yorkshire
Members Car: Skoda Fabia vRS Thanks: 0
| Just changed brake pads and... My left front brake (passenger side) last night started to make a hideous grinding noise, anyway as JBS suspected my brake pads had pretty much had it, anyway I struggled home. This morning I went to my local garage and got some new pads fitted and im guessing they were aftermarket ones (unsure what brand), i'm guessing they are aftermarket anyway as I can't see how he managed to get OEM pads in on the same day that I brought my car in. Anyway, brake pads changed and the feel in the brake pedal is almost none existant and to slow the car down even from a moderate speed I seem to have to really press the pedal in. How long do pads normally take to wear in and is this normal? My final question is (sorry this is going to sound really spackerish ), could normal Fabia pads (or their equivalent) of been fitted instead of the vRS ones, or do only vRS specific type of pads fit?Thanks
__________________ Metro Blue '06' 5 Door Astra 1.8 SRi |
| Pads will take around 200-300 miles to bed in fully on a used brake disc |
Members Car: 4x4 turbo estate Thanks: 17
| for starters skoda don't make the pads. they will be the same pads fitted to a few different cars so a good chance of getting them very quickly as they would be made by a big company. the brakes on't feel the same straightaway as they need to bed in for a hundred miles or so, so no heavy braking unless needed
Members Car: Fiat Panda Thanks: 15
| Briskodian Join Date: Jan 2005 Location: United Arab Emirates
| Dude... I just recently got my pads changed after about 70,000kms. My first brake pad change. They changed it...regardless of the fact it needs to be bed in for a while, they were bloody fantastic and responsive. So there must be something wrong, because new brake pads are thick, and therefore should braking should result in quick response.
__________________ Milton Kyvernitis Private Government |
| | #6 | |
| Briskodian Join Date: Oct 2003 Location: Cheshire
Members Car: '05 Fabia vRS Thanks: 0
| Quote:
New front pads are rather scary to the uninitiated - it's like having no brakes for the first 60 odd miles with increased pedal pressures. The bite gets gradually better until they're back to "normal" after a couple of hundred miles.
__________________ '05 Diamond Silver Fabia v/RS | |
| Don't talk, drive! Join Date: Feb 2003 Location: The B roads of Britain
Members Car: 1983 Porsche 928S / 1972 MGB GT Thanks: 16
| If the discs are worn they will have a pattern of grooves on them which the pad takes a while to wear down to match. Until that happens, contact between pad and disc is only on the high points between the grooves. Also the pads will have a shiny surface on them that takes a little while to wear off. They just need to be bedded in gradually. |
| | #8 | |
| Quote:
| Hmmm just guessing maybe the calipers squeeze harder because the pads are thicker and don't have to travel so far to meet the disc ... also of course the boiling point of the fluid will be higher because of the heat absorption qualities of the extra friction material, and there will be less gassing because of the sealed surface of the brand new pads, and, and, and ...... All complete piffle but I tried ![]() |
| | #10 |
| The distance from the pad to the disc never alters regardless of the pad width, the piston just moves out and takes up the space. |
| | #11 |
| Briskodian Join Date: Jan 2005 Location: Wigmore, Kent
Members Car: Black Fabia vRS Thanks: 14
| Cant really comment as Ive alway felt the vRS brakes to be kinda crap, if I keep it for another 6 months then ill upgrade the brakes for sure. |
| | #12 |
| Briskodian Join Date: Jan 2004 Location: North East England
Members Car: SEAT Leon TDI Sport Thanks: 34
| As far a I know, the vRS brakes are unique to the Fabia range, so they must be the pukka pads! While we're on the topic, has anybody fitted any type of fast road pad to the std 288mm brakes?
__________________ Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille. Also driving around in a Mini ONE that thinks it's a Cooper! John Cooper Works airbox, Superchips Bluefin remap, Sprint Booster, 17" Cooper S Spokes |
| | #13 | |
| Quote:
I did say it was all piffle ![]() | |
| | #14 |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
Members Car: Merc E class & SLK Thanks: 19
| Far canal, there ain't arf some excrement posted on here ![]() New pads need to be bedded in, end of. The bedding in procedure and the time taken to bed in varies with different types of pads. Thickness of the pads? Far king nonsense!
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| | #15 |
| Jon, yes. HTH
| | #16 | |
| Quote:
__________________ Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille. Also driving around in a Mini ONE that thinks it's a Cooper! John Cooper Works airbox, Superchips Bluefin remap, Sprint Booster, 17" Cooper S Spokes | |
| | #17 | |
| Urm probably Quote:
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() | |
| | #18 |
| C'mon, spill the beans! ![]()
| | #19 |
| DS2500s - I had them on my old Octy, too. In fact they're the same pads for either the 288 or the 312, same part number. |
| | #20 |
| Oh, hang on! Octy calipers are different to Furbys
| | #21 |
| Ah - disc sizes are a coincidence then. I assumed too much, knowing some people had swapped to 312 systems off Octavias. Sorry ![]() |
| | #22 |
| Thanks for all the replies guys, I have been out for a Briskodaly drive in it tonight, very light/light then medium braking over a period of approximately 50 miles. It seems much better already, cant wait till I can start stopping properly soon ![]()
| | #23 | |
| "Bones" Join Date: Jan 2004 Location: Heathrow/Crewe
Members Car: Fabia vRS Thanks: 0
| Quote:
How many miles did your pads last for? Just wondering because when mine are gettin to the end of their life I'll be upgrading to 312mm jobbies. So I'd like to know how much I "may" have left. Anyone else with a fabia vRS that has changed the pads due to being worn out?
__________________ Oh to have the internet back..................oh have I missed it | |
| | #24 | |
| BRISKODA Staff | Quote:
Obi-wan is telling the truth..what a load of bolleaux. Will take a couple of hundred mile to bed the pads in...it's a fact.
__________________ Adrian. | |
| | #25 |
| Briskodian Join Date: Sep 2004 Location: Leicestershire
Members Car: Smart Roadster Coupe Brabus Thanks: 4
| Just for info, releasing brakes does not remove the pad from the disk, it is the rotation of the disk that does that - this is why disks are hot after driving, even if you do not use the brakes. So as far as thicker pads moving less far etc this is untrue, as they are almost always touching the disk slightly.
__________________ Engined bike. Engined car. Neither a Skoda - been there, done that |
