39,358 Members 1,486,249 Posts
Just a stone....?
This is a discussion on Just a stone....? within the Fabia I forums, part of the Skoda Model Discussion Area category; Just saying Hi as a first time poster and in need a little advise if possible please. Driving home yesterday ...
Old 13-05-2007, 01:53   #1
Members Car:
Just a stone....?
Driving home yesterday my Fabia developed a horrible metallic scrapping noise from what seemed to be the front passenger side wheel. Best I can describe it is as if a shovel was being dragged along concrete only ten times as loud. Came on after the car had been moving for around 5 minutes and after I’d turned left off a main road at a junction.
Happened at all speeds up to 50 mph (not brave enough to go faster with that noise)
;-) but did not seem to effect braking, in fact all felt normal other than the racket.
Had a poke around underneath and all seemed well, so took it to the local car park and after 10 minutes or so driving in circles on full lock in both directions and some heavy braking and emergency stops the problem seems to have disappeared.
Could a stone trapped between the calliper and disk have cause this?
Car is a 03 Fabia 13,000 miles serviced April 07 (original pads)
Thanks
Merlin
merlin5965 is offline
Old 13-05-2007, 02:29   #2
King Rat
vRSLen's Avatar
Members Car: MK11 Octavia vRS
Re: Just a stone....?
Welcome
Sounds like it could have been a stone trapped. I would take the wheel off and
have a good look. Also examine the wheel for score marks.
Current car: Black MKII Octavia vRS Combi
Previous: Black MKI Octavia vRS Combi
Black Fabia Elegance 100 BHP
vRSLen is offline
Old 13-05-2007, 09:14   #3
vrs jamez27's Avatar
Hello and welcome, hope you find Briskoda helpful.
I agree with vRSLen, still take the wheel off and have a look. I had a similar problem on my 306 once, and I still couldnt see anything so i got the pressure washer out and gave the affect area a spray (not too close obv) this must have dislodged whatever was making the noise as i had no further problems. So you could try this method if the noise returns. Hopefully it will have been cured by your erratic car park driving
Furby's gone ... but never forgotten! Been replaced with Terri the Premier Ed Civic Type R.
Now using new Mums Octy vRS diesal estate ... having trouble convincing her to take to Jabba! Help needed.
I still wave at Furby vRS owners in my Type R and I sure they think Im retarded.
vrs jamez27 is offline
Old 13-05-2007, 09:23   #4
Members Car: ...............
We get called to his all the time, no need to remove the wheel, just turn wheels on full lock and then gently pull the disk backing plate away from the disk at the bottom and a little road chiping usually falls out.
This is much better than driving around trying to dislodge it.
Never yet seen any disk damage with this fault.
parsko is offline
Old 13-05-2007, 09:26   #5
Cool, have to remember this if it ever happens again.
Old 13-05-2007, 16:39   #6
rider of sharks
sharkrider's Avatar
Members Car: Fabia vRS
there was a brisky member with a vRS, who's wheel came apart, (the actual alloy split!) and skoda claimed it was due to a stone being caught, causing wear, weakness, and then the break!
Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red....
Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!)
sharkrider is offline
Old 13-05-2007, 16:58   #7
Members Car:
Many thanks for the replies and advise
Reverse light switch seems to have packed up now so i'll drive by the stealers and ask them to have a look at the same time.
Old 13-05-2007, 18:33   #8
King Rat
vRSLen's Avatar
Quite
vRSLen is offline
Old 14-05-2007, 08:18   #9
Smile Re: Just a stone....?
The fault as described exactly in the original post is a classic case of a chipping caught between disk and backplate and driving about as the original poster said had dislodged it.
It obviously goes without saying that if after checking between disk and backplate and moving the car a few metres the noise is still present it warrants further investigation.
This is not to be confused with grinding noise when applying the brakes normally pads worn out or disk corrosion.
Would love to have seen the evidence of a stone causing a wheel to split, imagine the noise and the ammount of time being driven before the wheel failed!
Although I am quite often amazed at what small faults can cause big failures.
Best be safe eh?
parsko is offline
Old 15-05-2007, 19:24   #10
fabmark's Avatar
Members Car: Fabia VRS
My mum has just had a similar problem in her 56 golf, it stuck between the wheel an dthe calliper somehow and has grooved the insidde of the alloy wheel.
Silver vRS, mudflaps and vw ipod kit, otherwise bog standard (for now)
fabmark is offline
Old 15-05-2007, 19:26   #11
rider of sharks
sharkrider's Avatar
Best be safe eh?
he showed us pictures if his wheel.... scared the hell out of me... I never ignored such a noise since! lol...
