Lowered, toe in problem
This is a discussion on Lowered, toe in problem within the Fabia I forums, part of the Skoda Model Discussion Area category; Just got my fabia lowered 40mm, the problem is that the car pulls to right while driving.. All other angles ...
Old 28-03-2006, 21:32   #1
All other angles are ok but rear axle has too mut toe in, left +0,20`and right +0,14`. This should be +0,11` (+-0,05`) according to autodata. The 0,06` degree difference between right and left makes the car pull to the right.
Are there any adjustment on the rear axle that can be changed to fix this problem?
EX 2006 Fabia 16V, Graphite Grey, black vRS interior
Etabeta sirio 205/40 17" Cooper Zeon 2XS,
Koni Sport springs & dampers -40mm
jjj84 is offline
Old 28-03-2006, 22:15   #2
I parked up 1st
ric04vrs's Avatar
Re: Lowered, toe in problem
i wouldn't have thought that that small amount out would make to much difference to vehicle driving in a straight line , the rear axle beam is a fixed geometry i.e. not adjustable . i'm assuming you've checked all the tyre pressures to be correct , did the fabia drive straight before you fitted the lowering springs ? you could try swapping the front wheels side to side (assuming they're not directional tyres) to see if the pull is the other way or gone completely
not so bored now
ric04vrs is offline
Old 29-03-2006, 08:15   #3
Car went straight before lowering.. I now have winter tyres on, they are almost new so i dont think that it swapping them would do any good. In couple of weeks im going to put summer tires on if it helps any, probably not. I have tryid different pressures, like 2.1bar in all other and 2.3 in the wheel that pulls car to left. No help, at least not much.
jjj84 is offline
Old 29-03-2006, 10:50   #4
Just visited skoda service, their official opinion was that there is nothing wrong with those wheel angles.
In another serviceplace they said that the problem would be Castor, that the left front tyre is too front..
3 different opinions, so im thinking of leaving it as it is now.. maybe the problem will fix it self when time goes on..
jjj84 is offline
Old 29-03-2006, 11:34   #5
CupraR-Rog's Avatar
Those settings shouldn't cause the car any problems - as can be seen the thrust angle is 0.03 degrees instead of 0.02 degrees, so we're talking negligable figures...
If you're worried, have the alignment checked else where... I once had my alignment done 3 times in 1 day (twice by the same garage) with different figures coming up on their systems each time... took about 10 different alignment centres before the car was finally set up properly - each time I had print outs showing "perfect" alignment, despite a steering wheel pointing to 2 o'clock!! (or 10 o'clock depending on garage!)
Some people say I'm stark raving bonkers...
...the others just smile and nod...
CupraR-Rog is offline
Old 29-03-2006, 17:13   #6
I had the same problem when I lowered mine (Eibach). After a day or so it settled in and has been fine since.
Monk is offline
Similar Threads
vRS: Fraying seats or Fuzzing seat material. You had this problem? waynef Fabia I 207 12-12-2007 22:18
throttle problem peterc INTRODUCE YOURSELF! First time visitors, say hello here. 1 07-07-2005 10:17
SERVICE NOW indicator problem Turbo_Boss Maintenance & Performance 9 09-08-2004 04:05
Hard Starting Problem With 1.8t Turbo_Boss Maintenance & Performance 19 25-01-2004 17:17
Starting Problem on 2002 L&K 1.8 T (EDITED) Turbo_Boss Maintenance & Performance 6 22-02-2003 17:07
