New CV Boot fitted... is there a problem
This is a discussion on New CV Boot fitted... is there a problem within the Fabia I forums, part of the Skoda Model Discussion Area category; I recently had a new outer CV boot fitted on the near side. I have noticed a couple of grease ...
Old 01-07-2006, 20:57   #1
toonartist's Avatar
Question New CV Boot fitted... is there a problem
I recently had a new outer CV boot fitted on the near side. I have noticed a couple of grease splaters on the wheel, it's not coated it is only the odd splater. Is this normal after a new boot is fitted or is there a problem with it..... Any feed back on this would be greatly appreciated. The car has been lowered! Ta
Duncan
Jabba Custom Remap - 190 bhp - 340 ib/ft Torque, Sachs Uprated Clutch, Eibach Springs, Jabba Rear ARB, 312mm Zimmermann Crossdrilled Brakes, Milltek Cat Back, Seat Strut Brace, Green air filter, Seat Cupra 160 intake, Pikey mod 1, Coded Grill.
toonartist is offline
Old 01-07-2006, 21:44   #2
DGW
BRISKODA Staff
DGW's Avatar
Default Re: New CV Boot fitted... is there a problem
Could it be grease from the old CV boot? I would remove the nearside wheel, thoroughly clean up the area around the repair, and then keep watch for any more grease appearing. Hopefully there will be none.
Denis
2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.09 mpg...
DGW is offline
Old 01-07-2006, 21:54   #3
U18 Automotive
Lummox's Avatar
Clip may have come off or been over tightened.
Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
Old 01-07-2006, 22:48   #4
toonartist's Avatar
I cleaned the wheel and the caliper down completely. When i took the wheel off to check it, there was a couple of splaters on the caliper and there was a little grease at the edge of the cv boot. I was wondering if it was to much grease packed in and forcing it's way out under pressure.
It isn't coming out the same way as the last boot did. The clip punctured the boot when it was on full lock.
edit... I will check the boot to make sure the clip hasn't punctured the boot.... if it is not this and the boot is intact, is it something to be concerned about or should it settle in time?
Duncan
