This is a discussion on New rear pads/disc - Handbrake not that good? within the Fabia I forums, part of the Skoda Model Discussion Area category; Recently changed the rear pads and discs (600 miles ago) now the handbrakes is poo. The lever makes around 4 ...
| Recently changed the rear pads and discs (600 miles ago) now the handbrakes is poo. The lever makes around 4 clicks with is ok. When on level ground with the handbrake on you can't drive off. But if you wanted to pull the handbrake at speed (say 1 point turn ) it does bugger all.What have I forgot to do also fluid has been changed.
__________________ John Take away the poor damping, inadequate bushes, heavy diesel lump and spongy brakes its not a bad warm hatch |
| Pads and discs not bedded in? Chris
| Was thinking that as the rears dont get used that much like the front. Might adapt the ferodo bedding in process to the handbrake ![]()
| Spend a day in Don's company and he'll bed them in for you Not sure he'd help your mpg problem though! ![]() Chris
| I have VAG COM Join Date: Jul 2006 Location: South Birmingham
| Mine handbrake to a few hundred mile before it started to get a good grip of the new discs.
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
| | #6 | |
| Quote:
__________________ John Take away the poor damping, inadequate bushes, heavy diesel lump and spongy brakes its not a bad warm hatch | |
