This is a discussion on Niggles - water ingress & courtesy light? within the Fabia I forums, part of the Skoda Model Discussion Area category; Now that it is getting lighter at night, I plan to help my son sort out the niggles on his ...
| Briskodian | Niggles - water ingress & courtesy light? Now that it is getting lighter at night, I plan to help my son sort out the niggles on his Furby, just out of warranty. Sometimes get water seeping into the rear footwells. There are tell-tale drops of rain water that indidate that it is getting in through the rear doors. Is this common or does it mean that someone has had the door panels off and not replaced the plastic liner properly? Also, the interior light does not come on when the drivers door is opened but it does with the passenger door. I assume that this is a micro-switch on the door lock, however this car does not have central locking? |
| Briskodian | Re: Niggles - water ingress & courtesy light? I heard the water thing is common. Im getting a new 06 VRS soon and would love to sort this before water gets in. How is this resolved? I have heard new rubber strips on door seals sorts it?
__________________ Fabia Vrs Blackmagic! Xenons, Cruise Control, Heated Seats and ESP Wednesday 12th may 2006 was my VRS day |
| Briskodian Join Date: Nov 2004 Location: Leighton Buzzard
Members Car: Fabia vRS Thanks: 10
| Re: Niggles - water ingress & courtesy light? I've just popped in to look for posts about rear-door leaks, because it's been raining all day and I just noticed my rear-carpets are sodden. Couldn't understand why the car was completely steamed up when i got in! I'm going to book it in asap, I'm assuming it'll be covered by warranty, it'd better be. Mine's a late 04 btw. |
| Briskodian Join Date: Jan 2006 Location: Skelmersdale
Members Car: Fabia vRS Thanks: 0
| Re: Niggles - water ingress & courtesy light? had my rear door seals replaced in january.all leaks have vanished.for the record my car is a 2004 march model so will be under warranty. |
| | #5 | |
| Re: Niggles - water ingress & courtesy light? Quote:
| | #6 | |
| Briskodian | Re: Niggles - water ingress & courtesy light? Quote:
Thanks Rog | |
| Re: Niggles - water ingress & courtesy light? window regulator, the bit that makes the window go up and down. The plate needs to be removed and sealed along its bottom edge s the water doesnt leak into the car. |
| | #8 | |
