PD 130 lump complete with ecu
This is a discussion on PD 130 lump complete with ecu within the Fabia I forums, part of the Skoda Model Discussion Area category; One for those mods that have gone wrong ? Parts & Accessories : VW Volkswagen Golf 1.9 GT TDI 130 ...
Old 09-03-2007, 20:51   #1
Parts & Accessories : VW Volkswagen Golf 1.9 GT TDI 130 PD Engine
Care should be taken, don't know how long the turbo has been sitting with no oil.
Glider is offline
Old 09-03-2007, 21:49   #2
Mongreller
devonutopia's Avatar
Images: 5
Re: PD 130 lump complete with ecu
Quite tempted as a spare.
Although I won't need any turbo's or ECU - tempted to make an offer for just the block itself....
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 10-03-2007, 12:01   #3
Escorted Estate
Word of warning (based on what's happened with my engine )
Even though the engine code is the same between the Fabia and Golf models, there ARE differences.
The most annoying one is the oil filter and associated stuff, I'm gonna explain this badly but basically it is at a different angle and standing away from the block, vs the Fabia one which is almost flush with the block. Also sensor wiring is on the other side.
As a result of this, plus an opportunity to buy a Fabia PD130 block with 11k on the clock for a reasonable premium, that's what's gonna be done now.
You CAN use loads of that engine though, so might still be worth it
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is online now
Old 10-03-2007, 12:59   #4
Cupra Bush King
Lummox's Avatar
Images: 2
Turbo is also different the the Fabia one as we know.
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is offline
Old 10-03-2007, 13:10   #5
Escorted Estate
Indeed - however the turbo (incl manifold) bolts over from the Fabia version to the Golf version. That said oil feed lines are different to the turbo so it gets messy quickly
Old 10-03-2007, 13:30   #6
Mongreller
Images: 5
In that case, if it's not a straight swap (with using my box and turbo) I won't bother.
Old 10-03-2007, 14:03   #7
Cupra Bush King
Lummox's Avatar
Images: 2
Its not that complicated to do. Basically there are just a few ancilleries that would need to be swapped over, the block itself is the same.
www.unit18.co.uk
Lummox is offline
Old 10-03-2007, 14:31   #8
Mongreller
Images: 5
So I could swap the oil filter housing over - what about the sump sensor plug - was that what was meant by "wrong side" ?? A sump would be easy enough to swap over though.
Old 10-03-2007, 14:45   #9
Turkish Delight
Johnwg's Avatar
Totaly off topic, but I was thinking about this the other day;
Jason, when you did your engine transplant were you never tempted to source a PD160 from a Ibiza Cupra (including the FMIC), or is it not possible to transplant one in to a Fabia?
2006: Silver: Octavia II VRS TFSI ESTATE
2002: Green: Audi A6 SE 1.9 TDI AVANT
Johnwg is offline
Old 10-03-2007, 15:06   #10
Mongreller
Images: 5
I wanted Skoda to try and maintain some common features. I'm not sure when the pd160 came out, but I planned my conversion in June/July 2005. Besides, with that I wanted to do with the pd130, there was really no difference between the two engines once I'd modded everything.
Old 10-03-2007, 15:13   #11
Hardcore
Basil's Avatar
When I was there at last TRAX - I saw a car that had TWO engines - they had put one in the rear as well.
Nice way to double your power, get the weight balanced 50:50 and have true 4-wheel drive. Economy would be an issue somewhat, methinks..
What do you think Jase? Sounds right up your street mate....
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 10-03-2007, 15:26   #12
Cupra Bush King
Lummox's Avatar
Images: 2
The problem is you have to get two very well matched engines. If they either differ to greatly or are set up differently then one just pulls or pushes the other.
www.unit18.co.uk
Lummox is offline
Old 10-03-2007, 15:32   #13
Hardcore
Basil's Avatar
so it's not unusual to do then mate?
Jase - where are you!!????
Basil is offline
Old 10-03-2007, 15:35   #14
Cupra Bush King
Lummox's Avatar
Images: 2
Plenty of twin engined cars around here. some I have seen..
Twin 2.0 16v MK1 Golf
Twin VR6 Turbo MK3 Golf
Twin 2.0 turbo Nova
Twin 3.0 Corsa
Twin 3.0 Pug 306
www.unit18.co.uk
Lummox is offline
Old 10-03-2007, 15:53   #15
Mongreller
Images: 5
Sorry, but the thought of having another pd130 in the boot, and the wiring/etc that would involve.... I would rather not.
Old 10-03-2007, 16:08   #16
Hardcore
Basil's Avatar
Talking Re: PD 130 lump complete with ecu
Twin 2.0 turbo Nova
Twin 3.0 Corsa
Twin 3.0 Pug 306
How the heck do they get the rear axle to run the power? Is it that they steal the rear axle from a VAG model or do they put in the front axle of a donor car?
If the latter, does this allow the setup for 4-wheel drive steering like the evo?
sounds totally mental but brilliant, I must say....
Jase - so you say now. Settle down for a few months and the modding bug will start biting again - and I have a feeling where you'll be headed, hehehe
Cheers!
Bas
Basil is offline
Old 10-03-2007, 16:09   #17
Mongreller
Images: 5
If I do anything it will be on a different car, whilst keeping the mongrel at it's new level. I might start scouring the car auctions for something to mess around with to give the mongrel a break. She needs it.
Old 10-03-2007, 16:26   #18
Hardcore
Basil's Avatar
Respect Mate!
Basil is offline
Old 10-03-2007, 18:45   #19
maxcars1's Avatar
Off topic - hows the mongrel going Jason? Had a progress check from Allards or has it been let out already?
100PD converted to 130 Spec Mods: To many too mention
maxcars1 is offline
Old 10-03-2007, 18:47   #20
Mongreller
Images: 5
Running on new gear / cam, but not being released until Monday after final checks.
Old 10-03-2007, 19:20   #21
Cupra Bush King
Lummox's Avatar
Images: 2
Cheers!
Bas
Usually either have a space frame at the rear or weld front chassis legs to the rear and mount it as front.
www.unit18.co.uk
Lummox is offline
Old 11-03-2007, 00:12   #22
Isn't a GT TDI a PD150?
oliverreed is offline
Old 11-03-2007, 00:13   #23
Mongreller
Images: 5
They had 130 ones I think too. ARL was 150, this is the 130 ASZ.
Old 11-03-2007, 00:24   #24
Turkish Delight
Johnwg's Avatar
It is along with the 115bhp (2 different versions, I think), 130bhp & 150bhp... take your pick!
Johnwg is offline
