This is a discussion on pd160 intake quesitons within the Fabia I forums, part of the Skoda Model Discussion Area category; Hello all. Just fitted this little number. Ordered it from VAG Parts cost me £44 delivered. Can't say I've noticed ...
| Briskodian Join Date: Jun 2007 Location: Brecon/ Cardiff
| pd160 intake quesitons Hello all. Just fitted this little number. Ordered it from VAG Parts cost me £44 delivered. Can't say I've noticed a difference yet but I guess the ECU takes a little time to adjust to the extra air. Looks nice in the engine bay doesnt it. Two questions: 1) I found the new pipe coming from the airbox doesnt sit quite tight to the new part connected to the slam panel bracket. Its only about a 4-5mm gap along the top but I assume this doesn't make any difference? 2) I noticed the slam panel part is still as restrictive as before, half of it is covered with the plastic flap and there is a small gap below the actual air intake? Is this to blow away excess water and prevent it getting into the pipe and so should it be left there? help appreicated.
__________________ '04 Fabia VRS - 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Boost + Volt Gauge, Window Tints |
| Briskodian Join Date: May 2005 Location: Midlands
| Re: pd160 intake quesitons I would imagine that part-throttle and top gear roll-on would improve as more air is (or should be) getting to where it matters, at least that's what I'm hoping as I have just bought one from VAGParts at the same price for my pd100. I'm sure I've seen folk on here advocating removing some of the restrictive flap on the slam panel, and others flamining them saying water will get into the airbox ... you pay your money, and take your choice! |
| Re: pd160 intake quesitons Never mind sorted the gap out with a black cable tie to now the pipe from the airbox sits nice and tight on the slam panel part.
| | #4 | |
| Re: pd160 intake quesitons Quote:
make sure the larger intake pipe does not chaff on the small coolant hoses the deflector flap on the slam panel can be opened out , but as has been said , you run a greater risk of water getting in , but if you drive through deep water , it will get in the air box anyway my flap is removed without any probs (up to now)
__________________ not so bored now | |
| Re: pd160 intake quesitons It is chafing but Im going to use a black cable tie to tie it to the plastic hose to the left of it.
| Re: pd160 intake quesitons the easy method is to twist the larger hose anti-clockwise on the housing under the smaller hoses , this moves all the smaller hoses away from the intake pipe
| Re: pd160 intake quesitons I didnt fancy twisting hoses in case something came loose! But anyway here are the pics. Not the prettiest engine bay but functional nonetheless ![]() ![]()
| Re: pd160 intake quesitons chicken ![]()
| Re: pd160 intake quesitons Hehe. Adding bits I am good at... fixing stuff thats already there.. well.. heheitll be ok like that wont it?
| | #10 |
| Re: pd160 intake quesitons just keep an eye on the area when you check your oil , there might be a gap there now , but when you accelerate the engine moves and may bring the intake pipe into contact with the hoses
| | #11 |
| Re: pd160 intake quesitons The cable tie will be alright on that pipe wont it? Because that wont be moving unlike the air intake and shouldnt chafe against it? Ive put it over the hard part where there is a little teet (ooo madam) underneath.
| | #12 |
| Re: pd160 intake quesitons it should be ok , just keep an eye on it
